Old 07-17-2016, 07:39 PM
Led Led is offline
Default Faders off Eucon command not working
Like it says, created both a surface button and touchscreen button with E\Global Eucon command 'faders off' and niether turns them off. The light on the button goes out while you hold it dow or your finger is on it on the touch screen, but the faders keep moving. Even holding the button down continously while playing back doesn't stop the faders moving.
Has anyone gotten it to work?
Old 07-20-2016, 03:28 PM
MoPro's Avatar
MoPro MoPro is offline
Default Re: Faders off Eucon command not working
What DAW are you using?
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 07-20-2016, 08:08 PM
Led Led is offline
Hi, Pro Tools 12.
Thanks
Old 07-24-2016, 11:07 AM
MoPro's Avatar
Hi, Pro Tools 12.
Thanks
Sorry for the Delay! I use Cubase 8.5.20, and not Pro Tools, so I cannot confirm for you!
But I can say that I have not been able to get it to work in Cubase either!
IMHO, to make such a useful function reliant on the third party implementation of EuCon Adapters is a step backward!
The reasoning behind the decision to go this route (To be able to use the Shift + Solo simultaneously) doesn't even make sense to me, or at least I have not yet been able find out why!
If any one can offer why Shift + Solo would be useful... especially at the expense of the "Faders Off" function... please enlighten me?
I realize that AVID says the "Faders Off" functionality is still there via a EuCon Command...but, AVID have stopped short of hard wiring the implementation of the function into the units themselves!
This has removed for everyone who owns / uses these devices, what I consider to be very, very useful functionality, and unnecessarily forces other DAW manufacturers to rewrite their EuCon Adapters just to implement a function that was already there!
The irony here is that it seems to not work for Pro Tools users either...
AL
Old 07-24-2016, 05:39 PM
Led Led is offline
Yeah , I work in post and do a loooot of automation. It sounds like an ice skating rink in here now..
one eucon command allowed in macro.. normal? jesse p Artist Series 4 02-03-2016 07:55 AM
Eucon Bypass Key Command on MC Control Problem KeyplayerG Artist Series 0 05-22-2015 06:10 PM
Command 8 and Eucon cananball Artist Series 1 01-08-2015 02:59 PM
d-Command and MC Transport / You cannot use EUCON with other Ethernet controllers wouters Artist Series 2 04-17-2014 01:28 PM
Command 8/Plugin Learning and EuCon mushoo Artist Series 1 07-28-2013 10:39 AM
