Old 09-06-2004, 10:37 AM
samrisio samrisio is offline
Default setup menu has no edit midi option? help?
i am trying to set up my midi studio within PT 6.4...WinXP...I am using the books I bought for PT and they say in order to setup the midi there should be an area to create a new configuration,,,any idea how to get there?
Old 09-06-2004, 10:41 AM
who who is offline
Default Re: setup menu has no edit midi option? help?
I think the book you are looking at is referring to setting up MIDI on a Mac, not a PC.
Old 09-06-2004, 10:47 AM
Default i will double check/are you saying it is set up
only thru the ins and outs?
Old 09-06-2004, 12:03 PM
who who is offline
Default Re: i will double check/are you saying it is set up
I don't think Pro Tools on the PC lets you do much of anything in terms of setting up a MIDI configuration. In the past you could turn individual MIDI I/O on and off, but for some reason they took that feature away. I don't think you can even rename the MIDI I/O to match the gear it is connected to.
Old 09-06-2004, 12:28 PM
well i recorded sampletank sounds on an auxiliary track and a midi track and it worked fine..then i tried BFD and nothing happens...no recognition in the midi track record...i set things to bfd input and midi channel one output..set to all and stereo track one and two..what gives?
Old 09-06-2004, 02:36 PM
who who is offline
Oh, I misunderstood what you were trying to do. I thought you were trying to setup a "studio" like you would with OMS on the Mac pre-OSX. I have no experience with BFD, so I can't help you there. Anyone else?
Old 09-06-2004, 04:51 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
BFD needs to have a kit loaded for it to work.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 09-06-2004, 06:48 PM
Default the kit IS loaded and I can hear it but
it is not recording in pro tools..does the groove librarian not record?
Old 09-06-2004, 07:29 PM
Cliffy_Boy's Avatar
Default Re: the kit IS loaded and I can hear it but
It does if you have a midi note to trigger the groove.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 09-06-2004, 09:40 PM
Default tease me..how do i do it then? midi note?
to trigger BFD...
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
midi device not listed in setup/peripheral menu larsendiese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-07-2008 12:17 AM
Midi problem - no INPUT DEVICE option in MIDI menu tam103 MIDI 2 01-05-2007 08:01 AM
No "Edit MIDI Studio Setup" Option! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-14-2005 06:42 PM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
