audio engine
I'm using superior drummer and after I bounce a track as a mp3 pro tools stops working and when I try to press play the stop button starts flashing and won't play.
Also, whenever that happens superior drummer plugin on the bottom right shows an error message "audio engine inactive check your audio device." The buffer sizes are matching and all that and pro tools works fine before I use beat detective and bounce. Dell XPS I9 64gb Ram 12th gen Intel 12900hk 2500 mhz..... Last edited by my-name-is-thanos; 03-23-2023 at 01:15 AM. |
Re: audio engine
Just inn case it matters, which exact version of Pro Tools and exact version of Superior Drummer?
I don't understand what "The buffer sizes are matching" means. Assuming you are using Beat Detective on the midi, instead of Bounce, what happens if you commit the track? If you just need an mp3 to email, you could export the committed audio as mp3
Connecting PT and RX7 with audio engine | nymills | Pro Tools | 6 | 07-26-2021 07:14 AM |
Audio engine | digiplex | Pro Tools 2018 | 7 | 04-09-2018 02:08 PM |
64 bit Audio Engine? | Numi | Pro Tools 11 | 1 | 04-28-2013 01:29 PM |
No m-audio interface in current engine (playback engine) | SlicerSounds | Windows | 1 | 10-04-2012 12:27 AM |
Audio Engine | twistedblues | Tips & Tricks | 1 | 03-24-2004 06:25 AM |
