Do I need Soundminer?
I bought Soundminer Ripper recently, I have Audio Finder, is it imperative I buy Soundminer as well? Yes, I'm being cheap.
Re: Do I need Soundminer?
Hi Mitch,
I only can say that I could not live without SoundMiner. May be Miniminer would be enough for you, don't know. Soundminer not only is a great product but the support is the best. |
I love Soundminer, but a cheaper and well made alternative is Basehead. I actually like it better than Netmix.
If Audio Finder works for you, then great. Whatever works. I have it in one of my rooms and I switched to SM HD. Soundminer came out with some lower cost versions which I like better than AF.
http://store.soundminer.com/mac-win-hd-product.html
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Don't forget to look at the very reasonably priced Soundminer HD products. Cheap, snazzy, powerful. Not everyone needs the full version of Soundminer.
Coming from soundminer, there were operational things that HD didn't have and it made getting through things difficult for me. I started with miniminer, a good way to start. I eventually upgraded to SM v4 Pro. |
Thanks to everyone who has replied. I'm still looking for someone who in some detail can disuade me from Audio Finder, with cost as a consideration. Audio Finder, can spot to PT, can edit an audio file, those are the two biggest needs, beyond the cataloging capabilities.
Pitch shift?
I have both Audiofinder and Soundminer V4 Pro, and I am currently in the middle of re-databasig my SFX library. The more I use Soundminer V4 Pro the more I realise it simply rocks! It is much more than just a SFX database and it is a serious metadata handling/ manipulation tool: It can batch rename files, batch append, copy and paste metadata from one category to another and then save all this info in BEXT to be available in any other database. This might not seem like a lot, but if you have SFX coming from a lot of different sources and/ or if you make you own sfx, sound design in big projects, etc., it helps a lot having all these tools in one central app.
But I believe that these features are exclusive to V4 Pro and are not available to the rest of the Soundminer product line though. So, if you were thinking about purchasing Soundminer HD, HD PLUS, etc, then I am not sure I can see a major difference. But I haven't used any of the other versions, just general knowledge here and what is written on the Soundminer website.. On the plus side for AudioFinder, it can handle REX files where Soundminer V4 cannot. But if I am not mistaken the new Soundminer HD range does support Recycle files. But feel free to correct me if I'm wrong. V4 indexes REX files but cannot play them back (mine crashes on the spot). Once I am done with the Soundminer databasing, I plan to migrate everything to Audiofinder as well. I will try and update this post if I make any significant finding that is not already covered. |
Hey! Thanks so much,. Your feedback is really helpful.
Soundminer or?? | soundboy35 | Pro Tools TDM Systems (Mac) | 4 | 03-27-2015 07:24 AM |
Soundminer XP | stealth | Post - Surround - Video | 1 | 08-11-2008 05:49 PM |
Soundminer or others?? | soundboy35 | Post - Surround - Video | 5 | 02-06-2008 02:44 PM |
SoundMiner for PC? | MGagnon | General Discussion | 2 | 09-01-2003 09:31 AM |
