7.3.1 LE and Quicktime 7
Searched but didnt find anything. A long time ago upgrading my QT crashed PT. I cant be sure what system i was running then but will QT 7.3.1 cause any issues with LE 7.3.1cs8 running on a
G5 10.4.11 002R ? after looking at the quicktime player "about" screen i can tell you i am running QuickTime 7.1.5 at the moment |
Re: 7.3.1 LE and Quicktime 7
If you want your digi hardware to continue to work with quicktime then don't go past 7.2. There has been a Quicktime core audio bug for months, the only workaround currently is to toggle between built in audio and digi HW to get playback, a complete PIA.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
hey
so if i upgrade, quicktime player is the only program that wont be able to use the digi or do you mean ProTools as well? I ask because i could handle it if only quicktime player was affected. |
It's quicktime only, VLC or the like works ok. Pro Tools is fine.
This is what I'm concerned about as well --
so basically what you're saying is that if I'm running OS 10.4.11 on a mac pro and install the latest Quicktime (7.whatever) it will *not* cause my PT LE to repeatedly crash, but will simply not be audible through the digi hardware? Thanks in advance for clarifying! |
Exactly.
All that will happen is when you try and play something through QT you won't get any audio unless open sys prefs and toggle between the built in audio and the digi HW.
QuickTime 7.6 | lego | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-21-2009 06:55 PM |
Quicktime Crash on Export to Quicktime Movie | Yosemite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-28-2007 12:44 PM |
HELP! HD 6.9.x on 10.4.x with quicktime 7.x ??? | brendo_91 | Pro Tools TDM Systems (Mac) | 1 | 07-24-2006 10:47 AM |
Quicktime | Wainui | Pro Tools TDM Systems (Win) | 6 | 01-29-2004 08:28 PM |
Major Problem Transfer TDM MAC Quicktime to PC Quicktime | audio1420 | Post - Surround - Video | 0 | 04-22-2003 09:41 PM |
