Aggregate causing sampling distortion having nothing to do with settings.
I am running several systems on Mac Minis with PT 10 using an Mbox 2 on Mac OS X 10.6.8.
I am only using the MBox 2, no other external devices with clocks. Issue: Often when I open a session, create a track and arm it, the signal (dynamic mic and voice) has what sounds like sampling distortion. It's a crackly/growling sound similar to digital clipping, but definitely is not from any gain staging issue. It is an intermittent problem and has nothing to do with any of the settings in the Aggregate window (only the Mbox is check with Resample unchecked. The built-in I/O is also unchecked.) I have had this problem on two separate Mac Minis and other Mboxes I've substituted on both systems. Short-term solution: Checking and unchecking the Resample box solves the problem immediately. Is anyone else experiencing this? Is this a software/compatibility issue? I'm at a total loss and would prefer to fix the problem properly. |
Re: Aggregate causing sampling distortion having nothing to do with settings.
i have the same issues.
This is a problem when using aggregate - in some cases the devices in the aggregate cannot 'sync' to each other properly. The solution - select just your Mbox in the Playback Engine.
Sometimes you need to reboot your Mac. Ps : i notice that This problem only occurs with Mac, not with PC. |
Non converted imported files have sampling distortion | timpearce | Pro Tools 10 | 1 | 06-13-2013 10:31 AM |
PRO TOOLS 10 Aggregate IO Distortion | r_w_breen | macOS | 8 | 09-09-2012 09:09 PM |
Aggregate I/O Built-in Speaker causing speaker to crack and pop | andrewkeithly | macOS | 2 | 01-27-2012 11:10 AM |
Smack! causing HORRIBLE distortion crackling problems | ProToolsIgniter | Pro Tools TDM Systems (Mac) | 2 | 05-23-2007 08:40 PM |
Sampling Errors and Distortion PT 6.0.1 | Digikid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-09-2003 09:34 PM |
