Old 03-16-2003, 09:09 AM
Kelso Kelso is offline
Default does midi w/ mbox works fine?
I'm planning to use midi with my mbox. I will probably buy an oxygen 8, and I wanted to know:
-Does it work fine using the usb as a midi port (the O8 is supposed to support this), or is it necessary to buy a midi interface to use it with PT+mbox ?
-Can I use the knobs with automation of plug-ins like I could do with a control surface?
And also I'm looking for a virtual synth, which can support home-made sounds in wav, in 24 bits/ 48 kHz; I've seen sampletank couldn't even do that. do you have any Idee, not including an external expander?
thanks for your help.
Old 03-22-2003, 01:32 PM
Default Re: does midi w/ mbox works fine?
up
Mbox CPU holding off USB audio. 002 works fine... Josh Fairhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-21-2010 01:11 AM
HP DV90610ev works fine with Mbox mini sonicapg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2008 11:57 PM
My Mbox works fine on the SiS chipset system i have? antonzedd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-14-2003 04:19 PM
Which new laptop works fine with Mbox BALLBURNS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2003 11:17 PM
Dell Inspiron 8200 works fine with Mbox ! Run Haugland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2003 09:31 AM
