Re: Small, misc problems/?\'s w/ PTLE. Please Help.
Latency.
Non humbucker or poorly shielded pickups in front of your CRT. [img]images/icons/rolleyes.gif[/img] |
Last night I was doing some harmony tracks in PT5 using the RenVerb plug-in and something very very ODD happened when singing along w/the other vocal track. I was singing the harmony perfectly, but some sort of weird "sound wave vibration" could be heard when I sang. It sounded kinda like a guitar string does when out of tune, as it gently gets tuned to pitch. And this was something that was TOTALLY not my fault as a singer. I managed to get it to stop after I brought the fader level down, but by no means was it too hot. Anyone ever experienced this? It happened numerous times on this session, and if I remember correctly, with or without the plug-in.
Another problem is when I create a new track, my I/O settings default to wierd settings. Like Mic/Line2 instead of 1, and buss-3-4 as the output and stuff. I checked my I/O settings and they all appear to be set correctly in the pref's so I'm not sure why this is happening. Also, I looked in the manual, and maybe I'm blind, but is there anyway to adjust the TIME in which a marker starts. Say I set it by hand at 3|1|320 and want it to be at 3|1|000. I can't figure out to re-adjust that start time. Finally, my monitor causes a dreadful buzz when tracking guitar. The only way to get around it is to turn my body/turn the monitor OFF while tracking. I was wondering if by chance a digial monitor causes this sort of thing to happen too. Thanks! Jason
Leo 10.5.7 PTLE 7.4.2, 002r, Micro iMac G5 2.33ghz Core Duo Intel OWC External FW HDD http://www.soundclick.com/jasonsheroan |
So, that fluttery sound is latency? I thought latecny was a delay in the signal? Not a "your vocals in a fan" effect.
Will a digital monitor fix the buzz then? Thanks. jason
People have actually recorded vocals thru a fan just for that effect.
You could be hearing the phasing between your vox and the recorded, or it could be the effect of hearing the sound inside your head phased with the returning delayed signal of your voice. You must run your signal thru a mixer or something that enables you to return the signal to headphones without going thru the digi HW. (mute the recording track in PT.) Only way I know to set marker positions: Drag the marker and watch the position in the info-field below the nudge field. I wouldnt sit close to a screen with a guitar pickup.
Mac mini M2 Pro 32/512. MacOS 13.6.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1. |
LCD monitor should greatly reduce the hum if you can afford one.
www.brianalexmusic.com |
FYI Brian, your songs are deliciously crafted. I'm very very impressed with them and your Bio.
Thanks! Jason
Disk Cache is too small? Problems! | AbjectEvolution | Pro Tools M-Powered (Win) | 10 | 02-21-2008 10:06 PM |
Many small but STRANGE problems in PT7 | Joseph Hanna | Pro Tools TDM Systems (Mac) | 1 | 11-15-2005 05:56 AM |
Couple small problems with PT...help | Keith Owens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-22-2005 08:07 PM |
few small problems need help with | Alex T. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-27-2005 09:48 PM |
Some Misc./beginner Vox questions | JEdmunds | Tips & Tricks | 3 | 06-22-2001 08:47 PM |
