#31
Re: MOMStreamDeckPlugin
Then unzip Luke's new version, double click on the: com.padl.monitoroperatingmodule.sdPlugin found there which reopens StreamDeck and you'll get the question on whether you want to install. Say yes. StreamDeck is back and all your settings are kept the same.
Pro Tools Ult 2024.10.1, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.1 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#32
https://lukehoward.com/ |
#33
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 1.0.0, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.6 Pro Tools Ultimate 2024.10.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#34
FYI,
Being a glutton for punishment, I updated to Stream Deck V 6.2.1 today. I'm happy to report that all is still working fine with the plugin.
#35
Hello everyone!
For those of you who are using multiple MOMs on duplicate networks, how are you setting them up? Whenever I try to connect to a MOM on a duplicated network, I get "connection error" on DADman |
#36
Did you enable EnablePluginRouter per the readme: Code:
defaults write com.padl.monitoroperatingmodule.sdPlugin EnablePluginRouter -int 2
#37
Yes, its enabled, I'm actually using 3 MOMs right now, built-in ethernet, wifi, and thunderbolt ethernet Quote:
tried duplicating Built in, yes, Ive tried restarting the app and the whole system, no luck. Today I tried again and now the duplicate interface is not seen by the streamdeck app |
#38
Yes, I tried all of that before, but no luck, I was actually using 3 MOMs on builtin, wifi and thunderbolt ethernet, but couldnt make it work with duplicates Not sure what changed, but today I deleted everything I could find stream deck related, and did a full reinstall of the stream deck app and plugins, reconfigured everything and its working now. Thanks for your help Luke! |
#39
Since StreamDeck 6.3.0 came out, I wanted to mention that all seems to be working/fine with the MOMStreamDeckPlugin (both on a StreamDeck regular size and a StreamDeck Plus.)
So if anyone is worried about doing the update, don't be.
#40
Thank you, just upgraded myself! :)
