Old 09-11-2001, 11:45 PM
trombino trombino is offline
Default Why doesn\'t PT look for files in the session\'s Audio folder first?
I occasionally get bit by this and I'm looking for an explanation as to why PT behaves this way... If I copy a session folder (including audio & fade files), then launch the copy, all audio files are still from the original audio folder and not the new audio folder. Is there a good reason for this behavior? I'm sure that there is, I'm just curious as to what it might be...
Mark
Old 09-12-2001, 07:50 AM
DigiTechSupt's Avatar
Default Re: Why doesn\'t PT look for files in the session\'s Audio folder first?
-This happens because the Pro Tools session file references the the Disk Allocation destination(s) from the last time the session was saved.
-In other words, when you copy the Session folder to a new location (in the Finder) and open it, the Session will look for the files on the orignal drive.
Brent
Avid Audio Tech Support
Support FAQ
Old 09-13-2001, 11:23 PM
But what's the reason for have PT behave this way? Wouldn't it be better to have PT look in the Audio Files folder first? In instances where you copy sessions in the finder it would seem to be yes, but there must be situations where this isn't the case, and I'm curious as to what those might be...
And, if I copy a session in the finder, open the copy, change it's disk allocation settings to the new disk, and reopen the copy, will it then use the copied audio files?
Thanks Brent.
Mark
Old 09-14-2001, 08:32 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>But what's the reason for have PT behave this way?<HR></BLOCKQUOTE>
I do not know that answer.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Wouldn't it be better to have PT look in the Audio Files folder first?<HR></BLOCKQUOTE>
-I was doing some experimenting and it looks like my Disk Allocation theory is incorrect. I was able to get a copy of the session to open and reference the audio files in the new location without being prompted with the "Where Is..?" dialogue.
Here is what I did:
-Copy (in the Finder) the session folder to a new location.
-Take the original session folder and change its location (drag onto the Desktop or into the Trash).
-Open the session file in the new location.
RESULTS:
-The copy of the session opened, referencing the audio at the new location.
-The Disk Allocation of the new session was still assigned to the orignal drive. Therefore, you will still have to go into the Disk Allocation window and manually change the Root Media Folder for your tracks.
Brent
Support FAQ
Old 09-14-2001, 10:22 AM
NK NK is offline
Trombino,
Does this happen for you if you copy a session to a new drive/folder by using the "Save Copy In" with copy all fades/ audio media options checked from within ptools?
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 12:50 PM
Splitting a session's audio files over multiple drives WildHoney Pro Tools TDM Systems (Mac) 6 05-10-2011 04:19 PM
Convert Session's Audio Folder from SoundDesigner II Dizzi45Z Pro Tools TDM Systems (Mac) 3 03-21-2011 11:19 PM
"fade file" folder out of my session's main folder! preachers Pro Tools TDM Systems (Mac) 1 03-11-2009 10:08 PM
Deleting unused regions, but the audio files still are in the session's folder....... Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-09-2001 08:11 AM
