Old 06-01-2006, 01:31 PM
soundboy35 soundboy35 is offline
Default Seperating Reason Drum tracks to Pro Tools
This may have been answered as far as using instrument tracks, but those of us still in 6.x, I'm not sure.
I want to record drum tracks from Reason into Pro Tools on seperate audio tracks.
Here's what I'm doing so far.
Create a Redrum kit in Reason
Route the seperate outputs of Redrum into the Reason interface (3-8)
Record my MIDI tracks for drums in Pro Tools
In Pro Tools, I create an audio track to monitor each Redrum track, which works.
The problem is that when I try to record the audio from Reason into PT, the sound goes away, and I get no signal into the audio tracks.
Since my 6.4.1 doesn't allow RTAS plugins on Aux tracks (which is the only way to open Reason/Rewire), do I need to create an audio track for each drum and then buss that to a seperate audio track to actually record the audio?
Kind of a pain, but I suppose if that's the only way...
Thanks,
Steve
G4 1.4ghz, OS 10.3.8
Mix Card, 3 DSP's
6.4.1 Software
2012 MacBook Pro 15in, 2.3gHz,i7
2013 MacBook Pro 15in, 2.7gHz,i7
PT 2020.9.1
PT12.8.x
Old 06-01-2006, 03:39 PM
TCDet TCDet is offline
Default Re: Seperating Reason Drum tracks to Pro Tools
If an audio track (on input only) is used for the RSN monitor then yes you need to route (Buss) that to a record track. When you upgrade you'll do this with either Instrument or aux tracks.
That said, once routed save the session copy (without audio) and use it as a RSN-patch template using session import into any session your doing this for.
I have pre-made RSN (Spider/split) templates that utilize all rewire connections (64) plus a stereo mirror Reason LR mix for quick monitoring. Took a couple of hours to build but saves a bundle of time from then on.
Old 06-01-2006, 04:38 PM
I had a feeling that might be the way I had to do it.
I do look forward to instrument tracks someday
Yes, it would make sense to make temlplates of these types of sessions,
as I use this setup a lot.
Thank you much,
Steve
PT 2020.9.1
PT12.8.x
seperating midi notes on different tracks? brokemusician3 Pro Tools TDM Systems (Mac) 3 05-08-2008 01:00 PM
seperating midi notes into individual tracks. tempest1226 MIDI 6 01-27-2008 08:58 AM
seperating tracks, setting master DB levels farside 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-14-2005 10:45 AM
Seperating one session into two tracks optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-11-2004 02:05 PM
ReCycle, Reason, Acid (On PC) Drum Tracks shareec70 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-24-2003 09:24 AM
