Mutes open/close late
With very light automation data, mutes open/close 3 to 4 secs late when "mute frees voice" is enabled. Turn it off, all works well.
Normally, I can usually figure this crap out myself, but this one has got me. Maybe someone else has run into this. The only new part of my setup is I added an expansion chassis. If no one has any ideas, I will remove the chassis, to see what that yields. And of course, I can just not use that feature, but I'm a "gotta know why", kinda guy. In automation prefs, memory reserved for automation recording is set to max allowable. I tried less, but no help. Setup: 33 tracks, 24 bit, Power Tower Pro/Newer Tech G3|250, Adaptec 2940U2W system 8.1 disk cache memory set to 1024 (tried more, and less but no help) Seagate 18 gig wide barracuda Mackie HUI Mix core Mix farm Mix farm Merle farm SCII Bit3 7 slot expansion 2 888|24s 1 888|20 2 Adat bridges DAE/DSI 3.4.2f9 - allocated 150 megs ram Ptools 4.3.2 - allocated 90 megs ram DAE options set to the second from the last setting. (i'm at home, and can't recall what it says) |
Re: Mutes open/close late
Yes, mute frees voices causes a delay with mute automation data. Always has, probably always will. Mix with mute frees voices off. I think you can decrease the dealy but not totally eliminate it if you set the DAE buffer lower or off.
probably best to seperate regions, then mute them instead of using mute automation...
Back to the old way.. |
Shortcut for Region Window Open/Close? | CEM3387 | Post - Surround - Video | 7 | 08-03-2015 09:28 PM |
10.3.4 Crashing on open/close of sessions | dj_grimmace | macOS | 3 | 03-15-2013 07:56 PM |
Is there a way to link track mutes to send mutes? | Ed Douglas | Tips & Tricks | 6 | 01-05-2010 07:39 PM |
ProjectMix faders do not always respond on open and close | Robbie Hollywood | Pro Tools M-Powered (Mac) | 4 | 08-03-2008 06:29 PM |
pro tools open and after a second they close | extratone | Pro Tools M-Powered (Win) | 5 | 11-20-2006 03:18 PM |
