Old 10-25-2003, 02:08 AM
Da Gatekeepa Da Gatekeepa is offline
Default Nuendo 2 with Asio driver! HELP!
Hi.
my system: athlon xp2200+/512mb ddr ram/radeon 7000 dual/40,80gb hdd 7200rpm
I'm getting clicks/pops using nuendo. does anyone get this as well?
buffer setting of 1024 seems ok, but it's too much latency.
i wanna run things at 256
any suggeestions?
Old 10-25-2003, 11:59 AM
Default Re: Nuendo 2 with Asio driver! HELP!
Which version of the ASIO driver are you running? How big a session, how many plug-ins?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-25-2003, 06:38 PM
asio version 6.1, plugins - some waves plugins.. probably about 15
vsti - 6.
Old 10-27-2003, 05:29 AM
bump
bump again
Old 10-27-2003, 12:59 PM
nikki-k nikki-k is offline
Hi! Saw the bumps, so I figured I would post a semi-answer...
I had N2 installed until a recent re-install of XP and everything else. I was using N2 for checking out VST's, VSTi's, etc, and was doing a comparison (for myself) of N2 vs PT. I actually had over 100 individual mono tracks of audio goin, bunch of plug-ins, highest (1024) HW setting. A bit extreme, but hey, wanted to see what I could push it to, like the Davec test. Could easily do over 32 tracks at lower HW settings (256 is my usual starting point, low enough most of the time) using the 6.1 ASIO drivers with a 001.
I have not re-installed N2 yet (gotta remember where I put my N2 cd ). I think I tweaked some settings in N2, once I reinstall I will post what I did. Should have it reinstalled sometime on the next few hours.
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 10-27-2003, 09:58 PM
Hi!
OK- all reinstalled. Tried out a 36 track session in N2 (ver 2.1, ASIO drivers for 001 from 6.1), HW set at 256. Smooth as silk.
A bit more detail on system, check driver versions, N2 ver, and things Rail asked about.
nikki k
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
ASIO 2.0 + Digidesign TDM Mix plus + Nuendo = ???? Black-Rose Pro Tools TDM Systems (Win) 2 11-09-2004 03:49 PM
001 & Asio Driver/Nuendo? yoyomama 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-06-2003 03:47 PM
Nuendo can't see Digi001 ASIO? cwild 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-27-2003 01:01 PM
ASIO test (Nuendo) Jayman#9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-23-2002 04:06 PM
