Old 03-24-2022, 03:22 PM
fork-media fork-media is offline
Default ADR and playlists
just recieved a session from a studio, for some reason they have recorded everything onto a seperate playlist
they just had one actor to record and instead of having a one playlist with the last/ approved take I have 107 playlists (x 2 tracks ) all with one cue on..
I'm asking them to resend, but if it doesnt appear then I'm going to have to deal with it
whats going to be the least painful way? to be honest I hardly use playlists. occasionally have 2 versions of music is about the extent of it.
I guess I can drag them in an spot to original TC? 214 sound files = 1 guess thats 107 lav 107 boom..
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 03-24-2022, 11:01 PM
clusterer clusterer is offline
Default Re: ADR and playlists
Guess u can do that with Fieldrecorder Workflow.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 03-27-2022, 05:31 AM
Pete Gates Pete Gates is offline
Feel for you, that's a horrible session to be presented with!
Pete
Old 03-28-2022, 01:52 AM
thanks guys - I guess I will find out in the morning how much googling I need to do on field recorder workflow.
On the bright side I'm not too pressured on this one for once so its an opportunity to get up to date if they dont deliver.
Old 04-05-2022, 04:23 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
You've probably edited this ADR by now, but if you get this again you can use the EdiLoad 'WAV File List' window to load all WAVs and export an AAF with them spotted to their timestamp. So you just ignore the session that was supplied and create your own. You can activate a free trial license within the app when first run.
Best regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 04-05-2022, 06:26 PM
smurfyou smurfyou is offline
Mark, that is a great suggestion. Wish I had thought of it when I had to deal with one of these.
FWIW I clearly specify no playlists when I book ADR now.
~Will
Old 04-06-2022, 12:19 AM
audiolex1 audiolex1 is offline
I just have a question. You said ADR.
Was this on set ADR with a location recorder or Pro Tools system?
I've gotten session from "obscure" studios around the US and have had weird playlist or only pref and alts in the session.
And Like you mentioned, give specs for what you need them to do. You'll get 16 bit, 44.1 and nothing labeled.
Quick sheet and instructions of setup for the session. Hopefully, you won't have to deal with this again.
Also, Check out https://www.soundsinsync.com
Mark, who is the developer, posted about EdiLoad.
I have EdiCue and EdiLoad and they have both made my life WAY, WAYYYY easier.
It is worth a look and he will give you an extension on the demo as well. I needed it to really get into EdiCue.
Can't work without either which is kind of scary. Don't go anywhere Mark!!!
Old 04-06-2022, 01:09 AM
thanks thats an interesting option
They did resend the ADR - but wasnt that accurate , but at least I had the takes 'somewhere close-ish' on one time line.....
cheers
HTML code is On
How to automatically expand playlists that are recorded using loop to new playlists ZdonTheRapper Pro Tools 12 4 03-17-2018 09:46 AM
playlists help anth Pro Tools 10 8 03-27-2012 06:50 PM
Where are the playlists? Mac88s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-27-2011 09:13 AM
Playlists goom Pro Tools TDM Systems (Mac) 6 09-22-2006 11:07 AM
mp3 PLAYLISTS cigam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-16-2004 07:29 PM
