How to create midi drums using Wav files
Hey all,
I've got some Wav audio files of all the individual drum sounds I want. To create my drums for my tracks I've been putting the wav audio hits on separate tracks for each drum and creating beats that way. However I haven't been able to find a way to humanise the wavs or utilise any velocity to make it sound more realistic. Was wanting to know if there is any software or easy way to humanise the wavs or if I could input my wavs into an existing midi drum plugin. Any feedback would be awesome. Thank you. |
Re: How to create midi drums using Wav files
Hi, welcome to the community.
Perhaps I didn't fully catch your idea, but whatever the case there is no reason to do it manually nowadays. First try the masseyplugins.com free plugin and see if it suits you at all, then take a look at the paid options which are plenty. Almost e every plugin maker has a drum replacement tool.
cheers for the reply, I just want the wavs I have for every single hit to become the Midi instrument. as if I created my own kit within xpand or what not. Hope that makes sense. I'm completely attached to the wav files I have, I've got the perfect kit for me, but they are all individual wav files and want to make them midi.
I would suggest, if you have a little money to spend, drop the manual laborious method with the wavs, and demo any of the many drum sample/sequencers out there, EZDrummer f.ex. Great samples, big midi library w/performances in many styles, very easy to use. It's $125, but there are cheaper options out there also. Added: Oh, and some of them will allow you to add your own samples, I'm shure. Although most drum software today use multiple samples, soft-to-hard on each drum, to create a more natural sound.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
There is no free demo? Sorry I didn't know if that is the case. Most of Massey's demos are not so crippled, but once you want to get rid of the limitations they are not so costly either.
The plugin is not free, like you wrote. Have you ever heard of a paid plugin demo? Yes Massey's demos are very little crippled, like you can use them forever, no noise or drupouts, most have no saved settings as the only limitation. DRT, I don't know. He doesn't say on his site. It's Audiosuite only, so I guess he's had to find a different solution to limiting expired demos.
2 other options to consider:
#1-use the Melodyne Audio-to-Midi feature(assuming you on a recent version of PT and have some version of Melodyne 5 installed). For sure, there will be some "cleanup" to do, but it can convert audio to midi. If you duplicate the audio and chop up each track to remove all but the specific drum you want, that would help. #2-Get Superior Drummer 3, which has a really good drum replacement feature. I dragged in the same stereo audio song file 3 times and set 1 to be kick, one to be snare and the 3rd to be hihat. Once it ran its analyze function, the results were shockingly good without any fussing(it would have taken some fussing to get a good final product, but all I needed was a drum beat without the other music that was baked into the audio file)
Dave, Janne; I think you are both missing the point. McBeat is not wanting drum replcement, he has some samples, and he wants to to be able to 'play' them.
SD3 is good, but I was just pointing out that it is beneficial to get used to drum replacement first with a free tool so OP would know if it is what he wants to do. Better paid options come later.
"can't create bounce files because would overwrite files used by this session" | lessajay | Pro Tools 11 | 4 | 08-03-2015 03:55 AM |
Adding MIDI drums to acoustic drums - Velocity | Pat.m | Pro Tools 11 | 5 | 11-01-2013 08:40 PM |
Need help - MIDI files with Drums From Hell question | drvibb | Virtual Instruments | 2 | 03-31-2008 02:03 PM |
editing drums - create regions frm multiple tracks | schmargle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-16-2005 10:24 AM |
how can i create good rock drums on my 001? | frankiejaxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 44 | 06-02-2003 09:36 AM |
