Old 12-23-2021, 03:56 PM
quieego quieego is offline
Default Should have I warped before comping?
Hello,
I've already created my 2 track guitars to have a stereo effect by comping several takes and mixing in 2 different tracks (see attach).
After doing the comp I realized that the original takes have some timing issues here and there.
Because both tracks uses repeated takes, I wonder if I can edit (elastic-time/warp) one clip of the take and see the same editions in the other clips of the same take to avoid repeating the process in the entire song.
Any idea?
Thanks!
Old 12-23-2021, 04:16 PM
Ben Jenssen's Avatar
Default Re: Should have I warped before comping?
You might try to make a group of the two tracks.
Old 12-25-2021, 08:52 AM
hmmm can you please elaborate?
Old 12-27-2021, 09:02 AM
Back to the original question; Yes, I would have fixed timing issues before copy/pasting audio. Having said that, at this point I would chalk it up as a lesson, fix the timing issues and re-paste(or fix each section as the clips are now). Now you're thinking, "why would I fix each section?" and that's a good question. There really is no "correct" answer, but I suggest it as it would allow you to make slight alterations throughout the song instead of having things sound....well....like they were copied and pasted
What you describe IS possible with midi clips, but I don't know of a way to do that with audio(but someone else may know better). Its called "mirrored editing"
Old 02-02-2022, 07:00 AM
Yes! like mirrored editing! that was more or less the original question, you've got it.
I agree, it's a matter of being carefull on each step to get it right before continuing as opposed to fix the timing at the last steps.
But again, it was a question of last resource like... hey, I screwed it, is something like mirror editing but with "warp" editing?
Nice to have this feedback! thx!
Audio seems to get warped thesk8rguitarist Pro Tools 11 8 09-09-2016 09:32 AM
Cannot export warped files Nesp Pro Tools M-Powered (Win) 3 02-19-2010 01:35 PM
Warped Sound shultzee13 Pro Tools M-Powered (Win) 0 04-19-2009 07:56 PM
warped/slow audio Crowly Pro Tools M-Powered (Win) 0 02-10-2008 10:12 AM
Warped TDM card ? rtreat Pro Tools TDM Systems (Mac) 0 10-03-2004 07:03 PM
