Old 05-06-2003, 07:17 PM
new engineer new engineer is offline
Default Does Reason 2 work with Digi 001 hardware?
I've had it. I downloaded the asio drivers from Propellerhead web-site, Unstuffed it, put them in the Reason Asio folder and changed the audio in the preferences to the asio Digidesign i/0 and it gives me a red cross..
I've thrown out all the duplicate asio files.
I get pops and clicks with Reason and my midi controller when I use sm digidesign sound.
What gives? I'm using protools 5.1 software on a mac g4 533mhz.
Btw, it worked at one point until I plugged in my midi controller into the usb port.
It should work right? or maybe it was a fluke...
[img]images/icons/confused.gif[/img]
Old 05-06-2003, 07:50 PM
Robocop Robocop is offline
Default Re: Does Reason 2 work with Digi 001 hardware?
yes, it should work and it will eventually. i had the same problem.what a pain in the ass. i can't seem to remember what made it finally work for me.
your doing it right it seems. try reinstalling the driver again.
Gabriel Roth Gabriel Roth is offline
works fine for me. make sure you have the right ASIO driver (download one from Steinberg here.
try trashing your digi preferences, restarting your computer -- all the obvious jazz. hope that helps.
Old 05-07-2003, 01:59 AM
Thanks, but it's still not working. I'm monitoring out of the digi 001. I'm still getting crackles while running sm digidesign and the red crosses still show up for the new driver.
What next? Anyone??????
Do I need to get a mixer and just come out of the headphone plug into mixer and then to speakers. What a waste of @$#!
Old 05-07-2003, 06:27 AM
The Mighty Burner The Mighty Burner is offline
I assume you have the digidesign sound panel installed?
The Burner
Old 05-07-2003, 07:39 AM
clockface clockface is offline
Is PT running or is your 001 being used as your computer's main sound output? I can only have one thing at a time patched thru my Digi - make sure that only one program is trying to use the 001 at any one moment.
Old 05-07-2003, 07:57 AM
jejefunkyman jejefunkyman is offline
Hello,
i have the same problem of cracks and noise in the digi001 with reason 2. I've tried the ASIO from steinberg, but it didn't change anything.
I wander if the problem could come from low RAM and processor, what do you think???
Old 05-07-2003, 08:15 AM
I'm not sure what the digidesign sound panel is. I know when I go into Reason's preferences sm Digidesign shows up as well as -asio digi I0, no sound- and sm built in. The sm built in works through my computers little speaker.
How can I get it to work through my 001?
The red crosses still show up on the asio digi direct IO.
Old 05-07-2003, 08:25 AM
KamaSutra77 KamaSutra77 is offline
The Core audio driver for OSX says it works with Reason 2.5 - yet to be released offcially.
Huh?
Old 05-07-2003, 08:39 AM
I'm using OS 9.2 because my plugins for protools le don't work in OS 10.
Apple's Hardware Test will not work with Digi card Erik Zobler Pro Tools TDM Systems (Mac) 8 09-01-2005 04:54 PM
QT 7 won't work w/Digi hardware plugged in? RadioMoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2005 08:23 PM
Why cant Digi make "Pro tools" work with out being hook up to the hardware Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-07-2003 02:03 PM
Digi hardware can't be found yet seems to work fine. Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-11-2002 10:43 PM
Will PTLE work with non-Digi hardware? sonicvi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-25-2001 07:20 AM
