Old 04-15-2013, 02:11 PM
Cosme's Avatar
Cosme Cosme is offline
Default How to Record Arm Record Enable using Axiom Pro Hyper Control
I'm on a mac with ptx. I read the Axiom DirectLink for Pro Tools
User Guide and didn't get anywhere. I did a search on here and didn't get anywhere.
I removed my Digi002 and replaced it with the Axiom Pro and now I can't work at lightning speed any more because I don't know how to record enable a track with the controller.
Thanks in advance for your help.
Old 04-16-2013, 04:56 AM
Cosme's Avatar
Default Re: I need help: How to record enable using Axiom Pro61 Hyper Control
If anyone else searches the web for this, I found the answer. Here it is:
Press the S18 button a few times while looking at the Axiom's display and you will see the bottom line of the display toggle between
[Track Mute], [Track Solo], [Track Select], [Record Arm] once you have the display on [Record Arm] you can use the other S switches to arm each track.
Axiom Pro, hyper control often freezes manik MIDI 1 03-11-2011 01:42 PM
Axiom 61 Hyper Control ??? frankielouis Pro Tools M-Powered (Win) 5 12-31-2009 12:17 PM
PT8 - HUI record enable leads to record-safe JMDNYC Pro Tools TDM Systems (Mac) 0 12-30-2008 06:33 AM
Record Enable via Midi Control change from Controller?? jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-17-2008 03:38 PM
Urgent: Record Enable greyed out--can't record! FlyingDisc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-25-2001 09:55 AM
