Old 09-24-2006, 06:52 PM
NZDingo NZDingo is offline
Default Protools LE transport - external control via MMC?
Does anyone know if you can setup protools LE so that it will receive tape transport control messages from an external midi device. I've got an M-Audio Axiom61 keyboard which has the standard transport controls ie stop, play rewind etc buttons. I'm wanting to see if I can set it up to trigger the protools transport.
Appreciate any ideas.
NZDingo
Old 09-24-2006, 08:13 PM
spkguitar's Avatar
Default Re: Protools LE transport - external control via M
Read appendix A of the MIDI Control Surfaces Guide.
Old 09-25-2006, 04:19 PM
Thanks spkguitar. Read through that and it didn't really help me that much.
Under setup/peripherals/machine control I have the USB Axiom Midi output selected.
That's the only place I can see in protools to configure this and still no joy getting the transport to start from the external controls.
Sigh.. I think I'm dumb.....
Old 09-26-2006, 07:47 AM
spkguitar's Avatar
Try reading my Tutorial on using the Ozonic as a control surface in Pro Tools. It is taken directly from that manual that I just linked you to (as well as a post from another DUC user who did the same thing...)
The procedure should be almost identical for the Axiom, seeing as how the Axiom is also an MAudio product.
Old 09-27-2006, 04:00 AM
Fantastic, works a treat. I just downloaded the xml file he had for Enigma and programmed the axiom as per his instructions (Axiom is almost identical to program as the Ozonic). Set protools to the CS10 and away she went.
Thanks heaps spkguitar.
Control external midi devices from Protools Dozerbabar MIDI 2 01-02-2011 03:24 AM
external control transport for PtoTools LE pickerdd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-08-2009 09:29 AM
axiom 25- transport control of protools Tomy DeClerque MIDI 0 06-05-2006 05:26 AM
Transport Control to Turn on/off External Lamp menotyou ProControl, Control|24, Command|8 5 11-01-2004 08:59 AM
external midi transport victhrill General Discussion 1 09-25-2004 08:27 AM
