Old 04-12-2006, 04:22 PM
AngelEarth AngelEarth is offline
Default Pro Tools without the hardware plugged in
Is it possible to use Pro Tools without the hardware plugged in.....
like say I'm on a 4 hour flight and I want to go through a bunch
of Stylus loops to set up favorites......
or I want to do some editing during the flight
is any of this possible?
I have the 002 board?
Would I need to purchase an mbox to run it that way?
Old 04-12-2006, 04:26 PM
GapeOne GapeOne is offline
Default Re: Pro Tools without the hardware plugged in
You'll need an mbox as PTLE doesn't run solo without hardware..
www.myspace.com/soulskool
Old 04-12-2006, 04:36 PM
spkguitar's Avatar
Better yet, buy the MAudio Transit and a copy of MPowered.
Old 04-13-2006, 12:10 AM
Matt Whritenour Matt Whritenour is offline
I have a transit, and the only thing i could say is that I wish there was a seperate headphone output with a volume control instead of it just being the line level and having to controlt he volume with the master fader because I dont feel that the signal is powerfull enough for my sennheiser HD280s.
so you can buy a small headphone amp like this, for 100 bucks
http://www.soundprofessionals.com/cg.../item/SP-HBA-2
or for about 40-50 dollars you can build one yourself
http://www.minidisc.org/headbanger.html
If I was doing this, I wouldnt get the belt clip, the ac adapter, and i'm sure you can get the battery cheaper.
www.klarityrecordingstudios.com
Old 04-13-2006, 12:15 AM
i just noticed that it was a rechargeable battery that's why there was the ac adapter, so maybe it would be a good idea to have that
Old 04-13-2006, 03:47 PM
Thanks all...........for all of your help
ok so here's what I did.........I bought an mbox2
which came with PT 7 but I want to stay at 6.7 for now
Is that possible?
and where would I find the software for the MBox2
without putting in PT7?
When I start up PT6.7 on my laptop with the mbox2 it says it can't find my hardware
........however if I plugin the 002 everything is fine
I miss tapes.....LOLOLOL
Old 04-13-2006, 04:51 PM
spkguitar's Avatar
The mbox 2 came out after 6.7 so it will not work with 6.7. Version 7 is the only one that will work for you.
Old 04-13-2006, 11:39 PM
well there was version 6.8.4 or something like that, that first came out only for the MBox2 and you couldn't even use the mbox 2 with 6.9. So your best bet is just PT7
Old 04-14-2006, 04:06 AM
spkguitar's Avatar
Yeah, it was 6.8.1, but that version only worked with the mBox2; it didn't recognize any other digi ineterfaces.
Old 04-14-2006, 07:04 AM
ok................
well thanks everyone
Peace
Mark W
pro tools crashes when keystudio is plugged in sterance Pro Tools SE and Essential (Win) 0 07-18-2010 07:42 AM
KeyStudio Plugged In - Hardware not found. Granof Pro Tools M-Powered (Mac) 0 04-27-2010 05:49 PM
Will Pro Tools ever not need hardware to be plugged in? garrett.ifland General Discussion 2 04-14-2010 04:15 PM
QT 7 won't work w/Digi hardware plugged in? RadioMoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2005 08:23 PM
Can't use Pro Tools/Mbox without decives plugged in? DeeZL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-03-2003 02:46 PM
