Missing plugins with new 2023.3 version
Hello everyone,
we just upgraded to 2023.3 and almost every third party plugins are now missing. (Mac mini M1, Mac OS 13.2.1) We can't find : Waves, iZotope, Arturia, most Native Instrument (except Guitar Rig, somehow???)... Weirdly, the soundtoys are there and running ?! (and also guitar rig) Yes, I restarted my computer. Yes, I updated my plugins. Anybody got a solution ? Thanks ! |
Re: Missing plugins with new 2023.3 version
PT now loads the Silicon version by default so what's probably happening is you've opened PT and all those plugins are not yet Silicon ready so they're absent from the list. Get Info on the ProTools app, select Open In Rosetta, open PT and you should see all those plugins again.
I'm having the same problem. I tried to install only 64 bit plugins.
What makes plugins compatible with silicon? I have a huge list of plugins that won't open, but they are checked as x64 with pro tools prefs 2. Avid pro plugins like pro compressor aren't compatible? |
You folks really need to get on your game, this stuff has been discussed to death here in many hundreds of posts over the last months, with lots of other users updating info on plugin support. Last edited by Darryl Ramm; 03-24-2023 at 05:23 PM. |
having the same problem and all plugins are compatible
You will find that you don't actually have AAX Native M1 (it's in the fine print on Plugin Alliance: all formats BUT AAX)
Plugin Alliance have no AAX native apple silicon plugins, you are confusing yourself with Plugin Alliance other plugin types being Apple Silicon native. All been discussed to death... but yes Plugin Alliance sure help by not making this obvious. Again, did you use PT Prefs 2 to actually see if the plugins you have installed are universal? Did you search DUC for all the recent posts on this? Again, you folks really need to get on your game, this stuff has been discussed to death here in many hundreds of posts over the last months, with lots of other users updating info on plugin support. |
ref screenshot attached.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
And just to cover the one corner case with PT Prefs 2. Softube plugins prior to the current/latest Softube plugin releases (which do support Apple silicon native) will show up in PT Prefs 2 marked as Universal when they are not. It's a problem caused by Softube having some Apple silicon code fragments in prior AAX plugins even when they did not actually support AAX native on Apple silicon. If your Softube plugins are not working you likely just need to upgrade to the latest.
In all other cases PT Prefs 2 is the go to tool... if it says a plugin is Universal it will be. If not it's not and you need to trust it/work out what is going on. |
I have Neold Big Al, U17 and v76u73 + phils cascade running on 2023 native.
@massivekerry, you're right; the clue to see this in PA manager is: ("M1 excl. AAX") - this means it's not aax native.
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
missing plugins - missing subscription pt12 | jazztronauts | Pro Tools 12 | 0 | 02-23-2016 09:38 AM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 10:27 AM |
H949 MassivePack Version-Missing in Ver.6.9.2 | JFK StudioDude | Pro Tools TDM Systems (Mac) | 6 | 06-05-2005 12:40 AM |
