UAD TDM PLUGINS NOT FOUND IN PLUGIN FOLDER
MY UAD PLUGS USED TO WORK. NOT THAT I PUT 7.4CS3. THEY ARE IN THE PLUG IN FOLDER BUT I GET DAE ERROR 7125 OR PLUGIN NOT FOUND IN FOLDER.
ANY SUGGESTIONS? THANKS |
Re: UAD TDM PLUGINS NOT FOUND IN PLUGIN FOLDER
Download the plugins again and re-install them and make sure you have the latest interlock drivers from pace. both below.. repair permissions also mighr help. http://www.uaudio.com/support/softwa...ols/index.html http://www.paceap.com/dlilpm.html Chris
Pro Tools requires the DSP mixer plugin in the plugins folder!!!!!! | crizdee | Pro Tools 10 | 13 | 10-23-2021 07:48 AM |
Nomad BT Plugins Problem "Not in Plugin Folder" | ddrew | macOS | 0 | 11-13-2011 05:30 PM |
Xpand! not found in the plugins folder, will not load. | SmokinBaldMonkey | Pro Tools TDM Systems (Mac) | 1 | 01-06-2008 03:21 AM |
Please locate the folder were PlugIns can be found: | LV | Tips & Tricks | 3 | 07-27-2002 04:43 PM |
Digidesign Plugin Folder Found in OS X! | PeeTee | General Discussion | 1 | 03-25-2001 01:01 AM |
