MIDI Drum Tracks in PT
I've got PT5.0 MixPlus. I would like to lay down some reasonable drum tracks as foundations for some tunes I'm constructing. I own and can play all the other instruments I need (don't want a drum kit - I have a drummer already). I'm also quite comfortable with PT and have been recording "real" instruments/people for several months. Just no MIDI exposure. I do understand the basic concepts of MIDI.
I assume I should have a sequencer so I can arrange my own tracks. What about PT's MIDI capability? What do I need to get setup to record some MIDI drum tracks on it? I would like to use "real" samples in my arrangements (i.e. GigaStudio sample CDs). How would I use these samples in PT? Do I need a sequencer outside of PT? What about a MIDI interface? Pardon my MIDI "Rookie"ness. I'm a guitar player. I've been a musician/sound engineer in the "audio" world for years, but have not been a "MIDI" guy. I'm sure it's pretty straightforward. I would like to buy the stuff I need and not the stuff I do not. Thanks a bunch for any good advice. Norm
Norm Couturier Little Barn Productions |
Re: MIDI Drum Tracks in PT
I use PT midi capabilities for my midi drum tracks.
I bought a Roland TD5K (drum pads + stands + drum sound module) so my drummer can play like a real drum (almost!!!). I have the feel of a real drummer and it's no way comparable to a drum machine played on a keyboard. I record midi information on a midi track and audio L-R on two audio tracks for alignment later on. I then split the single midi track to 8 new midi tracks to have each piece of the kit on is own track (pretty easy as each one is a single note). From that point you can easily direct each track to whatever sound module/sampler you want. You can also correct/align/wathever each note before mixing. When I'm ready to mix, I record audio from midi tracks. They're comming out of sound module/sampler. I align each track to previously recorded L-R audio tracks to get rid of midi timing. I't a simple solution that save CPU power (I have Digi001) until mixing as midi tracks are not using any resources (except if your using soft synth). Regards. ------------------ Donald Robidoux President Design Relationnel inc. www3.sympatico.ca/design.relationnel |
drum/midi tracks? | Intelli-Shred | The Drum Room | 4 | 02-27-2012 11:21 AM |
midi drum tracks in pt8 | Jahlal | MIDI | 3 | 01-11-2011 08:18 AM |
midi recording drum tracks | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2005 08:34 PM |
MIDI Tracks to Drum Machine | M Offutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-05-2005 04:34 PM |
sync midi drum tracks to wav tracks | Adrian D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-14-2003 12:24 AM |
