hooking alesis adat to project mix
I just purchased an alesis blackface adat so I could add 8 extra inputs to my project mix. Didnt have a whole lot of time to try to get it working. The Adat came with 2 lightpipe cables but no clock cables. I ran the lightpipe cables properly from the adat to my project mix but I am unable to get the extra channels in my pro tools. I messed around with my I/O setting and still couldnt get anything to happen. I also set my adat as a slave. The person i urchased the adat from told me the lightpipe cables were all i needed, Is this true or do I need a wordclock cable to run from my adat to my project mix.
I guess the best things to ask would be..... does anyone use a similar setup? Could anyone offer a step by step setup for an Alesis Blackface ADAT and a Project Mix. THANKS!!!!!!!!! |
Re: hooking alesis adat to project mix
UPDATE:
Figured I would update in case someone down the road has the same problem. I am also still looking for suggestions as I am still unsure if this is the best way to set this up. I have successfully hooked the Adat to my Project Mix and I can record 16 tracks at once. I have the lightpipe in and out connected from the project mix to the adat. I had to go into my adat and use the pitch control to change the sample rate to 44.1 (there is nothing in the adat manual about this but if you scroll through the pitch it will eventually show 44.1). Next I had to open my m audio control panel and set the sync source to external digital. This is something I am unsure of. I would much rather use the sync source from the project mix but every way I try causes noise and periodic clicks. Any suggestions on the achieving the best results and sound quality using this adat setup would be very much appreciated! ps....is it possible to hook 2 project mix consoles together through adat ?? im pretty sure the answer is no...but figured i would check. |
im trying to figure out the same problem. im using a project mix and want to light pipe a presonus firestudio into it. i went into m-audio firewire panel and choose adat in and out. I was told to use sync: internal digital unmuted. i will try external though and see what happens. i also created the path of 9-16 optical channels. i am still not getting it to sync. any help would be apreciated!
hooking up the M-audio project mix n eleven rack to pro tools | cdvh5150 | Eleven Rack | 4 | 02-24-2012 05:27 PM |
Help hooking up ADAT device | paronoff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-26-2004 10:08 PM |
Hooking up an ADAT bridge | FOH | Pro Tools TDM Systems (Mac) | 7 | 01-20-2003 01:23 PM |
Hooking up an ADAT bridge | FOH | General Discussion | 3 | 01-20-2003 08:13 AM |
Digi001 ADAT, Alesis ADAT Edit and Fostex VM00 | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-24-2001 08:57 AM |
