Video Issues - Ultimate 2024.6 HDX .MOV files
Greetings
I've been fighting with Pro Tools all day Video Export was working just fine up until today No idea what I changed Last Monday I imported video and audio, 'mixed' the audio and reported .MOV files no problem I've been back thru the last half a dozen versions of PT Trashed Pref's Fully Uninstalled & Reinstalled I've just reinstalled Mac OS X Sonoma 14.7 Reinstalled latest PT - 2024.6 Audio sessions all working great Tried to open a video session and get this error "This session contains media that is not supported possibly due to a missing CODEC." My understanding is PT works with Quicktime I went back and installed the AvidCodecsLE (2.7.3) But made no difference It's reached the point where I need to ask for help Thanks in advance
https://www.glasshousestudios.com.au Mac Studio M1 Max 32 GB ram macOS Sonoma 14.7 24 core Metal 3 GPU Avid MTRX Studio Pro Tools Ultimate 2024.6 HDX card AVID TB3 1 slot PCie Chassis |
Re: Video Issues - Ultimate 2024.6 HDX .MOV files
What actually is the codec used in the file/session you are trying to open? .mov tells nothing useful about that, it’s a container format.
What Avid claims to support is documented here and elsewhere: https://avidtech.my.salesforce-sites...e-Type-Support Installing Avid Codecs… again what exact format video are you actually working with? Can you open other sessions/files? Make sure the ones you are trying to open have not just got themselves corrupted. You may just be seeing a problem reported by others, e.g. https://duc.avid.com/showthread.php?p=2675003 You can use Google search to find more. |
As for the codec pack... that too is old news. Ventura onwards (maybe even Monterey) do not use the Avid codec pack because of Apple's restrictions. All Avid codecs are now incorporated into Apple's delivery (as they are required to.) You want to install the Apple Pro Video Formats package from Apple. The Avid codec package does nothing anymore (and it is noted in Avid's notes this info.)
Pro Tools Ult 2024.10.1, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.1 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
This is common knowledge so I apologize if you already know this. If you’re using any codec other than ProRes or DNxHD, that is most likely your problem. Convert any mp4 or random codec with Shutter Encoder and all should be good.
thanks for your help guys
much appreciated I'm going to look into all this now and see if I can get this sorted I'm def NOT a video guy - lol
OK..
The Apple Codec pack didn't work but converting using Shutter Encoder got the video files recognised However the video was still - wouldn't play Anyway I tried an export 2024.6 Ultimate crashed as soon as I selected go from Bounce Mix Installed 2023.12.1 and the bounce worked However near the end I got this error... "AVE reported an error at the completion of audio/ video export." I'm about ready to look for some other software to do video in The challenge is that I need all my plugins to work to mix the audio Plus I use Elastic audio to line up the audio capture from the mixing desk (nice stereo) with the audio capture on the video which is in mono
Converting in Shutter Encoder to what? You still have not mentioned the codec you originally started with.
Yes it would help us to know the exact codec and settings you used in Shutter Encoder. Or we could advise on what you should use if you're unsure.
Also delete all video tracks and remove all video clips from the bin before trying the newly converted video.
~Will |
Apologies
I have no way of finding out what format the original files were in originally They are a .MOV file However when I converted using Shutter Encoder I converted to AppleProRes with whatever the standard settings are I've emptied all the unused audio and video files from the Clips Just tried again to do a Bounce Mix Same error comes up "AVE reported an error at the completion of audio/ video export." When I click 'ok' pro tools crashes
OK
I watched a short video on YouTube and tried selecting Apple ProRes as the Bounce Mix codec under Transcode Default Compression - ProRes Proxy And it's now working
Video Sync bounce PT 2024.6 Ultimate | Cryos | Pro Tools | 10 | 09-15-2024 08:15 PM |
FS: PT 10/11/12/2024.6 Ultimate Perpetual | SLK | Buy & Sell | 0 | 08-29-2024 09:21 PM |
Pro Tools Ultimate 2024 - won’t start | Ronniedawg | Pro Tools TDM Systems (Win) | 1 | 05-10-2024 06:07 AM |
PT Ultimate 2024.3.1 | mhender | Pro Tools | 7 | 04-24-2024 08:38 AM |
Video files in ProTools Ultimate | IrelandM | Post - Surround - Video | 4 | 06-28-2023 03:17 PM |
