Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-29-2023, 01:27 PM
audiobadger audiobadger is offline
Default Wiring for unbalanced line inputs / outputs
Hi all,
Just waiting on my new Carbon to arrive, and getting cabling sorted out. I can't find any reference in the manual, so would welcome a steer on what is the correct wiring approach to connect the balanced line in / outs on Carbon to unbalanced equipment?
Thanks!
Old 01-29-2023, 01:58 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Wiring for unbalanced line inputs / outputs
Hi, welcome to the community.
If the manual does not mention anything about this, like for example 20yr old DigiDesign 192 mentions you should not ground the extra pin, you solder the balanced connector cold pin (number three on xlr) to ground.
Janne
Old 01-29-2023, 02:09 PM
Thanks! I have indeed got a number of cables made up as you describe, but was concerned by the warnings on older Avid interfaces. Given there's no big warning about this, seems like a go-er... (what can possibly go wrong???).
Old 01-29-2023, 02:15 PM
Top Jimmy's Avatar
Given that the Mon outs are 1/4" which allows for either TRS or TS, it may very well be the case that the DB25 outs are driven the same meaning it won't matter one way or the other whether pin 3 is left floating or terminated to ground.
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
Old 01-31-2023, 07:48 AM
K Roche's Avatar
K Roche K Roche is offline
Not sure if this is answering the OP question BUT as far as the DB 25 there is a chart in the manual page 52
System :
Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Wiring up an 888|24 - balanced/unbalanced HSLand Pro Tools TDM Systems (Mac) 2 02-15-2014 09:03 AM
MBox Pro Line inputs: Balanced/unbalanced LincolnT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-06-2009 09:40 AM
Mbox 2 Unbalanced outputs? D.Don 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-05-2005 09:21 AM
unbalanced vs balanced outputs Rivritt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-09-2005 06:25 PM
MBOX: can i stop feeding inputs into line outputs? Alexey Lukin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-17-2003 11:59 AM
