Overnight, VE instance pushes CPU 30%-40%
Hey guys, without any change, I noticed that my instance of VE in my mix session bumps the CPU usage 30%-40%
Anyone else has this bug? This session sat around 50% last night and today is in the 80's
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Overnight, VE instance pushes CPU 30%-40%
Rebooted. Didn't help... Anyone else? VE people also suggesting memory leak. Workaround anyone? Lior ____________________ Sent from an inherently faulty typing apparatus... ;-)
Trashing prefs seems to have done the job...
I made sure to build clean prefs on a blank session, quit, restart, and ONLY THEN open the last session. CPU usage is down to the 50% area now.
Aaaaaaand it's back. Took al of 3 minutes.
Yes- PT prefs. How do you address a memory leak?
VERY strange symptoms. I went back to the clean session I saved today (of last night's mix) after the prefs trash and it's fine... (with the same VE session attached to it) If I import a plugin from last night's session (A UAD SSL strip) it jumps back up BUT doesn't go away when I remove the plug. (that track is NOT sending to VE)
Seems to be related to internal bussing... When I Open the session, it's fine. Then, when I put my 'print track' into INPUT, the session jumps 35% I've been working this way for YEARS and it never behaved this way...
But I rarely pay attention to the cpu usage window in PT anyway. Unless I have an issue I don't even open it. |
banking pushes tracks to top of screen | Goombot | Artist Series | 13 | 10-27-2015 06:57 AM |
Bounce to Disk adds 120 samples - pushes out of sync w pics | bootc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2008 06:50 PM |
Fade Pushes Track Forward | emcicle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-11-2007 05:07 PM |
Do we turn the computer off overnight? | jeremyroberts | Pro Tools TDM Systems (Mac) | 6 | 07-18-2005 09:13 AM |
overnight timecode problem | audiokraftwerk | Pro Tools TDM Systems (Mac) | 1 | 03-14-2001 06:51 AM |
