  #21
Old 08-17-2022, 07:14 AM
Markrosoft Markrosoft is offline
Default Re: Pro Tools 2022.7 is out now
Have you tested whether this version fixes the midi recording errors of the past 5+ years?
There have been many, many posts on here but just to summarize: You can record midi in pro tools and play exactly on the beat but then during playback it moves the midi notes ahead of the beat! I have tested this by recording the audio during the performance and making sure that the performance was exactly in time or behind the beat. But then when you stop recording, for some reason the midi notes shift ahead! So now playback of the recording sounds quite different than the performance -- it's always ahead of where you played it. The buffer size affects by how much but it always shifts it ahead of where you play. What this means in effect, is that if you record a performance that is behind the beat it will often be so shifted that it ends up AHEAD of the beat during playback. Again, this has been reported many times over the past 5-10 years and I've yet to find someone who has tested it and NOT found this happening.
Anyway, curious if 2022.6 or 2022.7 fix this issue. Any help would be much appreciated!
  #22
Old 08-18-2022, 08:29 AM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
For those of us that are Post Production oriented, Re-Mixers, Sound Designers, Dialogue Editors....etc, is there any feedback picture and sync related?
Any issues with plugins, AAF imports etc????
Cheers
JT
JoeTools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Big Sur
Pro Tools Ultimate 2021.12
Mac Mini M1 16GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
  #23
Old 08-21-2022, 02:43 PM
jeff markham's Avatar
jeff markham jeff markham is offline
The midi editor has some serious issues. Using the grabber tool in the midi editor, grabbing a note an moving it does not work. It also doesn't sound when pressing the note.
In the velocity editor, I can hear the volume of the note changing as I move the diamond up and down, but the visual doesn't show a change.
I wound up using the score editor to move the note, but it too, doesn't show the note on the stave where it is sounding.
So I think 2022.7 is a no-go if you edit MIDI.
  #24
Old 08-21-2022, 03:39 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Yes. MIDI is totally useless in 22.7. But it's been discovered that switching temporarily to sample mode can enable you to edit midi notes. This has now enabled me to use 22.7 again.
MSI Pro Z690-A | i712700k @ 5.1GHz | 64GB DDR4 | 8TB NVMe /14TB WD Black | Audient iD14 | PT 2022.7 | Win 11 Pro | Tons of VIs and plugins
  #25
Old 09-01-2022, 02:28 PM
Thanks for that .. how on earth did that release get through QA.
  #26
Old 09-01-2022, 02:52 PM
Well .. interestingly .. Avid Link showed an update on 22.7 .. even though they didn't bump the revision number?
Anyways, after it installed, MIDI started behaving again. .. only weird thing was it removed PT from the Dock (Mac).
  #27
Old 09-02-2022, 08:40 AM
originalscottyg originalscottyg is online now
Yes, there was a glitch with the first installers released for 2022.7, as they didn't include certain bug fixes. There was a second installer released that fixed those omissions. 2022.7.105, I believe. There is a sticky thread about it in this forum.
Here is a link to page 2 where Jeffro explains:
https://duc.avid.com/showthread.php?t=421232&page=2
Scott Gatteño
  #28
Old 09-03-2022, 08:15 AM
Sean Read Sean Read is offline
Thanks for this
I'm having the same problems unable to select or edit notes in the MIDI editor
Pro Tools 2022.6 won't launch Scheak80 Windows 5 07-27-2022 09:15 AM
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 Alécio Costa Pro Tools 4 06-01-2022 11:58 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
Pro Tools Subforum - 2022 or ? Tweakhead General Discussion 22 05-02-2022 12:35 PM
