Old 01-23-2022, 11:58 AM
alhardy alhardy is offline
Default MIDI gets recorded early
Hi and thanks for checking this out.
Every MIDI I record in realtime gets printed early.
But the audio I hear in realtime is fine, and I tested it.
TEST : Record midi on a Virtual instrument track and it's audio out to a different track at the same time
RESULT: The midi is clearly ahead of the audio.
In the attached screenshot, midi track (Blue) and audio track (purple) are recorded together in realtime while playing. You can see midi is early.
The 3rd track (pink) is recorded after the realtime performance and it aligns with midi, but midi is of course recorded early.
I tried already :
Turned off delay comp
Tried a simple midi track (not the one of the VI)
Different VI plug ins
I am on mac mini M1 and latest PT, on Big Sur.
Had this issue on a different system too.
Avid support is working on it, but no luck so far.
Alberto Lombardi
Carbon - Pro Tools
Mac Mini M1
Ferrofish 16 I/O
www.albertolombardi.com
facebook - instagram - youtube
Old 01-27-2022, 08:52 AM
Default Re: MIDI gets recorded early
Anybody encountering the problem or have a clue?
Alberto Lombardi
Carbon - Pro Tools
Mac Mini M1
Ferrofish 16 I/O
Old 04-12-2022, 12:42 AM
nd nd is offline
This problem happens all the bloody time!
Seems it's a ingrained Pro Tools problem.
How are people getting around this?
Nudge notes every time you record MIDI?
What a PITA.
Old 04-12-2022, 05:57 AM
tonwurm's Avatar
tonwurm tonwurm is offline
this bug has existed for years, so far avid has not been able to fix it (or don't care)
Therefore: midi recoding in Pro Tools is a serious problem
...and I'm afraid it will stay that way... similar to all the other bugs that have existed for years and have not been fixed
MP 5,1 12core 3.46ghz 96GB Catalina
PT Ultimate Logic DP VEPro
PT10 HD3 Mavericks
MacBook Mainstage
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 04-12-2022, 09:00 AM
You should be able to add a delay in the Realtime Properties to compensate. Once you figure out the right setting, just add that(or build it into a Track Preset).
Old 04-12-2022, 10:46 AM
rinky rinky is offline
This problem just popped up for me about a month ago.
Frustrating knowing that this problem existed for some time now.
PT Ultimate 2022.6
PT HDX
MacPro 7,1
16 Core
96 GB ram
macOS Monterey 12.5.1
Somehow, musicians are now technicians!
Old 04-12-2022, 07:30 PM
nd nd is offline
Will this actually auto move notes on the grid though?
What’s on screen needs to reflect what we hear, so we can edit properly, add notes in, etc…
Old 04-13-2022, 01:01 AM
Reml@P Reml@P is offline
Originally Posted by tonwurm View Post
This bug has existed for years, so far AVID has not been able to fix it... Therefore: MIDI recording in Pro Tools is a serious problem
I know this is not what anyone wants to hear but you're better off not using Pro Tools for MIDI. I've never found it to be a serious solution in that capacity.
If you're on Mac, use Logic. On PC, Cubase or Nuendo. These programs handle VST instruments and MIDI far more elegantly than Pro Tools ever has, or likely will.
Old 04-13-2022, 01:08 AM
tonwurm's Avatar
Thanks for responding ! That´s what I´m doing...I use Logic and DP for more than 30 years
But sometimes it would be very handy to record some midi tracks in PT... but you can't get everything you want, obviously ;-)
PT10 HD3 Mavericks
MacBook Mainstage
Old 04-13-2022, 01:11 AM
tonwurm's Avatar
Thanks for responding ! I've tried that of course... but the lag isn't constant, it varies depending on the tempo and it's not consistent there either... crazy
PT10 HD3 Mavericks
MacBook Mainstage
Recorded Audio from MIDI Instrument Placed Early on Timeline? taylor4814 Pro Tools 2019 10 03-02-2020 11:28 AM
MIDI being recorded early rosindabow Pro Tools 2018 3 10-15-2019 05:40 AM
Recorded audio placed 40ms too early peteage FireWire & USB Audio Interfaces (Win) 3 09-11-2013 08:05 PM
Midi recorded early allstaar macOS 2 05-09-2011 03:27 PM
Click plug in is early when recorded stormpro Pro Tools TDM Systems (Mac) 5 08-13-2006 10:23 AM
