Old 05-02-2018, 10:25 AM
PaddyFlash PaddyFlash is offline
Default Memory Marker Shortcut?
Hi Everyone,
I'm running Pro Tools 2018.4.0 on Windows 10, on a laptop with no numeric keypad. I'm trying to figure out if there is a keyboard shortcut to add a memory marker. I read it's normally "Enter" on a numeric keypad, but alas my laptop doesn't have that. I've tried every combination of my Enter key and other keys, but nothing seems to work. Will I just have to deal with clicking to add a marker, or is there something I'm missing? I've tried searching on google, but all the solutions seem to be for Mac, and don't appear to work on Windows 10.
Cheers!
Old 05-02-2018, 10:49 AM
BScout BScout is offline
Default Re: Memory Marker Shortcut?
There is no workaround.
Most laptops have a numlock feature. With that turned on, a section of keys act as a numeric pad. In that mode, some keyboards will have a key (or enter) act as the num pad enter.
You could also use something like Sharpkeys to remap a keyboard key to the num pad Enter. Basic rundown here:
https://www.howtogeek.com/howto/wind...dows-xp-vista/
Usually easiest to remap one of the CTRL, Alt, or Shift keys since there are two on the keyboard. I usually use right CTRL since I normally press left Control for Control.
Old 05-02-2018, 11:13 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
You could buy an inexpensive usb numeric pad.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 05-02-2018, 12:05 PM
its2loud its2loud is offline
If your laptop has a function (Fn) key. Try pressing that and the Return key to make a marker. The Fn key might make the Return fucntion as the numeric Enter. It does on a Mac
Old 08-15-2021, 10:02 AM
Ben Jenssen's Avatar
Thanks for that. Very useful for me as I'm getting more and more into using my old Command|8 together with SSL UC1 to work on mixes without PT on screen.
Another nice trick I just picked up; if you have the cursor in the memory locations timeline, you can tab to the next memory location. Alt/opt-tab to go to previous marker.
Old 08-15-2021, 10:10 AM
The Weed's Avatar
The Weed The Weed is offline
Ben, you can also highlight the area between Markers with the same keyboard shortcuts you would with audio, then Shift+; to make that highlighted area include a track or tracks under the Markers Timeline. Then in Shuffle, you can delete that area and the Marker(s) will move up. Great for dropping in Markers for later editing.
Another use for Markers is to put the Grid in Clips & Markers and then you can separate any Clips at the beginning and end of Clips and at Markers.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-15-2021, 10:25 AM
Thanks, Bruce.
All info welcome, but for me now, I'm mostly digging up old projects to remix, so there is almost no editing. But man, am I having fun using my "virtual SSL 9000" (C8+UC1) to remix the best bands I had in my studio two decades ago. Almost without mouse/screen.
Old 08-29-2021, 09:51 AM
EGS's Avatar
EGS EGS is offline
...I've tried every combination of my Enter key and other keys, but nothing seems to work...
What laptop model? Have you confirmed the enter key is dead i.e. not working on any/all apps? If the keyboard is damaged, try opening up & clean it, replace it, or add an external kbd. There's a pref in PTools re setting markers. Have you tried that?
Click for audio/video demo
Click for resume
Old 04-18-2023, 09:19 PM
RafaelOvni RafaelOvni is offline
Does anybody knows a keyboard shortcut for dropping markers during playback when using a MacBook Pro (details in my signature) without a numeric keypad?
Thank you
RafaelOvni
Apple MacBook Pro 16", M1 Pro chip with 10-Core CPU and 16-Core GPU, 32GB Memory, 1TB SSD Late 2021, OS Ventura 13.3
Focusrite Clarett +8
Pro Tools Studio Perpetual License Version 2022, updated 2023.3.0
Old 04-18-2023, 11:05 PM
Thank you
shortcut needed: tab next marker/ prev marker Sir Hannes Getting Started 7 03-28-2018 09:01 AM
shortcut for select to next marker Neale Eckstein Pro Tools TDM Systems (Mac) 7 10-01-2015 07:36 AM
Marker shortcut >9 MediaBrain Tips & Tricks 1 05-10-2015 05:34 AM
Keyboard shortcut for jumping from marker to marker... shotgunndunn macOS 1 11-28-2012 07:45 AM
keyboard shortcut for next/previous marker ? rexdiver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-10-2004 09:59 AM
