[Q] How To Change All Output Assignments At Once?
Is there a quick key for assigning all the outputs for every channel at the same time?
I need to change every output to the same output for a bunch of sessions, and was hoping there was an easy way to set this. Thanks Jason |
Re: [Q] How To Change All Output Assignments At Once?
You can select all of the channels you are going to change and then press shift-option-(Outputs).
Is this what you mean?
bookerv12 |
or just option if it's "EVERYTHING"
Ray Trujillo Freelance Audio Engineer |
Thanks, both answers worked. Thought I tried them but I guess not. Thanks for the quick response!!
Jason |
Thanks! |
Thanks!!
The Option modifier key in Pro Tools affects All Channels.. so Option click on one to select all.... The Shift+Option modifier selects/targets all selected tracks... this is a global modifier in Pro Tools and is used for multiple commands.
Rail
In Windows on ProTools 9:
Hold Alt while changing the I / O on one of the tracks, and this will apply to all. |
output assignments on D-Command | zakco | ICON & C|24 | 3 | 09-07-2012 03:51 PM |
Another Strike quibble - output assignments | Che_Guitarra | Virtual Instruments | 12 | 08-18-2009 11:06 AM |
Odd output assignments | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-24-2009 05:20 PM |
Multiple Output Assignments | scottives | Pro Tools TDM Systems (Mac) | 4 | 08-02-2006 05:25 PM |
SampleCell & bulk output assignments | Farmer Dave | Digidesign Hardware & Software | 2 | 01-14-1999 11:55 AM |
