i want to monitor the input signal w/plugs during playback, but not record it...
Is this possible? I know there would be some latency. I'm using LE 5.2 and an mbox.
Joseph Grimm 3 3 . 3 A R C A R O T H E L I L Y W H I T E C A B E Z A D E V A C A |
Re: i want to monitor the input signal w/plugs during playback, but not record it...
Yes, Run the signal thru a buss to an Aux in with the effect on the aux and monitor the aux while you record your main. The latency is only like 10-14 samples... I don't think you will even notice it.
Hope it helps... D-
G5 Quad 2.5 Digi 002 G5 D 2.0 HD 3 Accel Control 24 - (2)192's |
If you just want to monitor a plugin, insert it on to the channel that you are recording with.
It takes a lot more work than that it you actually want to print the plugin's sound to a track.
Digi001 * Pro Tools LE v5.2beta * Mac G4 733Mhz * 1.5gb RAM 40gb internal HD * Lacie 40gb firewire HD * Radeon 7000 dual-display http://www.erikkarter.batcave.net |
sorry, i guess i didn't explain myself well... I want to run the input signal through the plug-ins, while playing back the other tracks, WITHOUT recording anything.
It's for a live performance, i just want to be able to play back pre-recorded stuff while also playing some music live and manipulating the sound with plugs.
Create an aux track and set the input to your live sound source. You can use effects but if you use low latency mode I think your effects are bypassed.
Marty |
thanks mpb!
Input meter skyrocketed when record enabled,reinstalled,now there's no signal at all | Psycho Tuna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-20-2014 05:56 AM |
Input signal still live during playback? | Red-Dave | Pro Tools 10 | 0 | 10-09-2012 01:25 PM |
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal | changa86 | Pro Tools M-Powered (Mac) | 3 | 12-18-2009 10:06 PM |
input & output signal when arm to record mode | rahman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-30-2005 07:39 AM |
Using an Aux Input to record plug ins on incoming signal...Discuss.. | Jules | Tips & Tricks | 8 | 03-19-2001 04:38 AM |
