Old 01-31-2023, 10:45 AM
pron022020 pron022020 is offline
Default Re: Advice for PC or build
Thanks for all the advice. General ideas:
32gb RAM
Intel i7 processor
M.2 drives
Windows 11
[plenty of cooling that is also quiet]
at least 3 USBC ports, maybe also a Thunderbolt
Old 01-31-2023, 12:32 PM
32gb RAM
Intel i7 processor
M.2 drives
Windows 11
I'd be more specific.
i7 is a fairly meaningless marketing term, and covers a decade and a half of processors.
I'd much rather have a current gen i5 than a two gen old i7. As I already said, I'd be trying to be on Raptor Lake and then you can get i5 or i7 depending on what you can afford.
M.2 NVMe/PCIe on PCIe4? And specifically I'd get a WD Black SN850 or Samsung 980 Pro drives. Both PCIe 4.
USB-C supporting what USB 3.2 Gen 1, Gen 2? Gen 2x2?
If Thunderbolt is needed that helps narrow motherboards.
There have been recent threads about current gen motherboards you can search for. And you should be doing research in that main DUC build thread... and it's not specific to i7. https://duc.avid.com/showthread.php?t=238426&page=706
Old 01-31-2023, 05:43 PM
ejinbc ejinbc is offline
OP
Free Advice Alert
With your budget the best deal will be a modern machine. I have found that upgrading every 5 years is a good plan. I went from a 3700K to an 8700K to a new 13900K system. You get a big enough jump in performance with these upgrades to justify the $$. I must say I am very happy with the 13900K for the projects I run.
I had a minute so I spec'd a minimum system (IMHO) for running Pro Tools in 2023. Yes, you can get cheaper but I don't think that's a good idea.
If you look at the attached, that's kind of the minimum full system. Many PC stores that sell parts will build and test a system like this for a few hundred dollars.
If you play games add a video card; if you have extra cash go for the 13900K; need more storage add a 2T M.2 drive; even more extra cash improve the Motherboard;...
Hope that helps.
ejinbc
Old 02-15-2023, 06:53 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Myself I would save up and go for an I9 build. Another thing maybe to consider is if your gonna Hackintosh your build in the future. If so make sure your motherboard is one that's easy to hack and don't use Samsung NVE M.2 drives cause of trim. Almost all other brand M.2 drives will work in a Hackintosh system.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Switching to PC New build advice!! jeandogon Pro Tools TDM Systems (Win) 2 09-10-2010 12:14 PM
Issue with new i7 build... need some advice. JamJuice Pro Tools M-Powered (Win) 5 09-22-2009 09:43 AM
Advice on First PC Build Paul_Cantor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 01-23-2009 12:06 AM
Need advice on a pc build ASHENASH General Discussion 0 01-06-2004 02:59 PM
Need to build a split, need advice. audio junkie Pro Tools TDM Systems (Mac) 6 12-03-2002 05:21 PM
