New system drive now -9093 errors
My system drive failed, so I opted to replace it and do a fully clean install. After getting everything back to the way it was previously, I'm getting -9093 errors with only a couple tracks playing a single audio file with some stock plugins instantiated. I've trashed prefs, done recommended optimizations running ONLY PTs install plugins, pulled my extra I/O out, so I'm ONLY running the HD Native TB and OMNI.
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
Re: New system drive now -9093 errors
Since you have been inside it I would first double check internals especially to make sure you didn't knock any RAM loose or something similar.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Ah. Good point. Although, I'm troubleshooting further and indications at this point are that it is an issue with my OWC Thunderbolt 2 dock. Currently running happily (with stock plugs only) on the Mini alone. I'm missing my ultra-wide display that requires the Dock video card to work though. Gonna be a bummer if that is the culprit.
The readme's and several threads here show a lot of issues with graphic cards, or unsupported displays also , so keep that in mind
Tim? Chicago Tim? “O” Tim?
What kind of drive did you replace it with? How did you format? I’ve had my dock cause errors but it’s odd that you’d only get this after replacing the drive. If you have a time machine backup of the old system try restoring and see what happens. |
I'm currently testing the system with no dock and adding back 3rd party plugins individually and running a minimal test session for an hour continuously. Strangely enough (and FRUSTRATING). This morning, when I booted up the computer and launched Pro Tools and opened my test session (same setup/plugins that were working last night playing for hours without issue), the CPU usage was sitting at 2% but spiking to 100% and I got the 9093 error on first playback. I quit and relaunched and it seems to be working now. WTF!?
Yes, I think. Do I know you? "O"....Ah.. "O" I get it. Yes, I'm "O"'s Tim. ; )
Update: This morning, playing test session fine (after a quit relaunch as noted earlier). I moved all the "Air FX" bundled plugins into the plugins folder. Launch Pro Tools and open my test session, and I'm back to spiking CPU. Quit and relaunch, and now it's seems to be fine.
Ha Ha, Tim, its MG. How are you man?
Getting 9093 Errors on a new PTHD 12 Native System | JB Retro City | macOS | 7 | 01-04-2016 12:44 AM |
9073 Errors Since Opening Logic On Same System Drive | RubyQueen | Pro Tools TDM Systems (Mac) | 2 | 05-13-2013 12:07 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
-9093 same old errors and I've tried EVERYTHING | unclecolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-19-2006 12:02 AM |
-9073 Errors after adding 120GB drive to system. | Sickstring420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 09-02-2004 07:38 PM |
