Old 07-03-2016, 11:27 AM
Kevtav Kevtav is offline
Default Can't Get Audio To Route/Bus Into Audio Track
So I've looked at multiple videos and read for an hour and I can't solve it.
I am trying to do a simple route from my Instrument track into an audio track. I've gone through the bussing configuration every way possible and can't get any signal on my audio track.
On my I/O setting I am matching the INPUT, with the OUTPUT of the track I want to bus, but nothing. I've tried multiple configs.
I thought of doing a POST record bounce, but I need live monitoring and recording. I thought maybe it was a monitoring issue since I can see the 'monitor' speaker icon in the Stereo L+R in the pull down menu, but I have no clue.
It's frustrating. Any ideas? I ran all out.
Old 07-03-2016, 11:40 AM
Drew Mazurek's Avatar
Default Re: Can't Get Audio To Route/Bus Into Audio Track
Remember, because of auto input monitoring, you won't get nay signal when you press play. You have to hit record once it's all set up.
Also, depending on the PT version you're using, you could use Commit or drag and drop MIDI to audio.
See here.
www.drewmazurek.com
Old 07-03-2016, 03:55 PM
Thanks.
I'm actually trying to ReWire some Reason tacks into PT. And I'm splitting the tracks, and trying bus them to an audio track to make them audio files.
I tried record to see whether the signal was coming in an it's not printing to the audio track. I get signals if I route to an Auxiliary Track (If I make one) I see the meter active, but nothing on an audio track. Even when record enabled and in Record Mode.
I hope that's more specific.
Old 07-03-2016, 03:57 PM
Also, I am having EXTREME latency/skipping when I play the ReWire form the REASON side. Almost unplayable.
While if I listen to a ReWire'd song from the Pro Tools side/window, it's playing fine. No buffering.
Something is really off
Old 07-03-2016, 04:33 PM
Figured it all out and was ALL solved by me checking the FREAKING monitor button. I didn't have it enabled. What a mind job. 2 hours over this.
How to route USB audio into Pro Tools Armando Pro Tools TDM Systems (Mac) 8 06-12-2018 07:43 PM
Need a bit of help getting Apogee 200 to route audio DrFord General Discussion 0 04-24-2010 11:28 PM
help: how to route the out 1-2 back to an audio track? PT8 Mpowered + audiophile jotawagner Pro Tools M-Powered (Win) 0 03-06-2009 09:45 AM
Can't route CPU audio thru I/O! mrdecibel Pro Tools TDM Systems (Mac) 2 05-28-2004 05:04 PM
Output to speakers from 2 soundcards + how to get MIDI track to route to audio LTEtabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-09-2001 01:07 PM
