Old 04-12-2012, 09:38 AM
sphereman sphereman is offline
Default Automation Latency
Apologies if this has been discussed in depth before, but couldnt find anything on this. When writing automation, I notice that the volume graph will jump back after I hit stop. Im hearing it one way while writing the automation, and playback is a little late. The amount varies depending on the playback buffer size. The larger the buffer size the more it jumps back. This seems kind of "non pro" to me. If I turn off delay compensation it does not do it. Kind of need that on though especially when using lots of UA plug ins. Any insight on this would be greatly appreciated. This is not unique to PT 10 either. Happened under PT 9 as well. Im not past the limit on DC for PT either. Reminds me of the Allison automation days!!
PT 10.0.1
Mac Pro Nehalem 24GB ram
HD3 PCI-X
Magma expansion chassis
OS 10.7.2
Old 06-08-2012, 06:46 PM
DWB DWB is offline
Default Re: Automation Latency
I have the same problem. Anyone have a fix? I do see a commonality in that I'm using UA plugs as well.
PT v9
HD|Native
MacPro octacore
C24 worksurface
Old 07-01-2012, 01:56 PM
DWB DWB is offline
After a little more testing: DISABLE DELAY COMPENSATION while writing automation was a workaround. The above problems were still there even on a new, blank session with one empty audio track. Hopefully Avid will fix this annoying little problem that is obviously Pro Tools and not third party plug-in related.
Old 09-14-2012, 06:12 AM
WildHoney WildHoney is offline
Same issue here. No UAD plugins. I tested it in a session with one audio track, routed directly to physical outputs. w/ no plugins, automation was written in time. With one plugin on the audio track (I used a Waves Linear Phase EQ) the automation was visibly and audibly written late. ProTools 9.0.6 -- this is not a ProTools 10 issue solely.
PT HD4, 9.0.6
OSX 10.7
MacPro 2012, 20GB RAM
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
volume/trim automation latency problem levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-17-2008 02:03 PM
Why is there so much plugin automation latency? Ale Pro Tools TDM Systems (Mac) 2 02-26-2007 08:40 AM
Aux /automation won't work with low latency recording switched on. Kling3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-07-2001 06:53 PM
automation latency RTAS (LE) & TDM (mix+) lancebrwn Pro Tools TDM Systems (Mac) 1 04-14-2001 12:08 AM
