SiSoftware Sandra
Computer Model : Toshiba Satellite A505 Workgroup : WORKGROUP Host Name : Matt-PC User : Matt Processor Model : Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz Speed : 2.13GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Toshiba Portable PC BIOS : INSYDE 1.20 01/25/2010 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.8GB DDR3 SO-DIMM Chipset Model : Toshiba Core (Auburndale/Havendale) DRAM Controller Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 4GB DDR3 SO-DIMM Shared Memory : 34MB Channels : 2 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Micron 16JSF25664HZ-1G1F1 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Micron 16JSF25664HZ-1G1F1 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : Intel(R) Graphics Media Accelerator HD (12 SM4.0 667MHz, 64MB DDR3 1GHz 128-bit, Integrated Graphics) Graphics Processor Storage Devices Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, 7MB Cache) : 466GB (C:) HL-DT-ST DVDRAM GT20F (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (D:) Logical Storage Devices TI105322W0F (C:) : 454GB (NTFS) @ Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, 7MB Cache) System : 1GB (NTFS) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GT20F (SATA150, DVD+-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1 : Toshiba HM55 LPC Interface Controller LPC Legacy Controller 1 : Winbond WPCE775LA Audio Device : Toshiba P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Disk Controller : Toshiba P55/PM55/3400 4 port SATA AHCI Controller Disk Controller : Toshiba PCIe SD/MMC Host Controller USB Controller 1 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe FE Family Controller Wireless Adapter 1 : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : Off-Line Battery No 1 : 71% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.6 |
It might be, and it might not be. There's really no way to know for sure on a non-Avid qualified PC until you try it. I run a similar i3 based laptop made by Fujitsu. When I first got it it had 4GB RAM, and it ran fine with PTLE 8.0.4. I've since updated it to 8GB and PT9. The RAM upgrade seems to have had no effect at all, but that's what I expected with a 32-bit DAW.
Many people will tell you that it will not work due to the integrated graphics. Mine has the same integrated graphics controller as yours, and I have no trouble at all running PTLE or PT9. You WILL NEED a second hard drive for your sessions, and it must be a 7200 RPM drive. Avid does not qualify USB2 drives for PTLE (they are qualified for PT9), but I think in Windows 7 the USB2 drives are fine in PTLE or PT9. A SATA drive, either external or internal is the best way to go if you can manage that. Sessions should not be run on a 5400 RPM drive like the system drive you have, and they should not be run on the system drive anyway. Here's my Sandra just for comparison: SiSoftware Sandra Computer Model : FUJITSU LIFEBOOK AH530 Workgroup : MSHOME Host Name : Mike-PC User : Mike Processor Model : Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz Speed : 2.26GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : FUJITSU FJNBB06 BIOS : FUJITSU // Phoenix Technologies Ltd. Version 1.14 06/10/2010 Bus(es) : X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 7.8GB DDR3 SO-DIMM Chipset Model : Fujitsu Core (Auburndale/Havendale) DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Total Memory : 8GB DDR3 SO-DIMM Shared Memory : 34MB Channels : 2 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : G.Skill F3-10666CL9-4GBSQ 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-10666CL9-4GBSQ 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : Intel(R) Graphics Media Accelerator HD (12 SM4.0 667MHz, 64MB DDR3 2x533MHz, Integrated Graphics) Graphics Processor Storage Devices WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (C:) (D:) SAMSUNG HD103SI (1TB, USB/SATA, 3.5", 7200rpm, 32MB Cache) : 932GB (G:) TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk : 200MB (NTFS) External (G:) : 932GB (NTFS) @ SAMSUNG HD103SI (1TB, USB/SATA, 3.5", 7200rpm, 32MB Cache) Hard Disk (C:) : 225GB (NTFS) @ WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Hard Disk (D:) : 225GB (NTFS) @ WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Hard Disk : 16GB (NTFS) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Fujitsu HM55 LPC Interface Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Fujitsu P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Disk Controller : Fujitsu P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP LaserJet Professional CM1410 Series PCL 6 (600x600, Colour) Printer : hp LaserJet 1012 HB (600x600) Printer : Epson Stylus Photo R200 (M) (360x360, USB, Colour) Scanners and Cameras Scanner : Hewlett-Packard HP LJ CM1410 MFP Series Scan (Scanner, 1200x1200, USB) Network Services Network Adapter : Realtek PCIe GBE Family Controller Network Adapter : Check Point Virtual Network Adapter For SSL Network Extender Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.4
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
So what kind of hard drive should I get to go along with it??
I would go Glyph or G-Drive. I just picked up a 1TB Glyph GT050Q drive for $175. They are pricier than most, but for audio and video editing, I find them to be way more reliable.
I've picked up two Iomega 1TB USB2 drives for about $60 each, and they both work great for PT. I got one from Frys, and the other from Staples. Problem is, they don't have any specs listed on the box, so you don't know what you're really getting until you plug it in. But I'm 2-for-2 on these cheap 7200 RPM USB2 drives.
Any 7200 RPM hard drive is fine. There is nothing special about a Glyph drive except the price is higher.
If you have an E-Sata port, get an E-Sata external, most E-Sata drives also have USB2 ports as well. If you have 2 internal bays, get another internal. WD Scorpio Black's work fine. As mentioned, your integrated video is not approved. Its not a matter of it working or not, its simply not approved. Quote:
Also your OS drive should be 7200 RPM as well Quote:
USB2 drives are approved for PT9 running on Windows 7, and Firewire is not approved. Some have suggested that USB2 drives will work fine with PT8.0.5 on Windows 7 as well, and they should be correct, but i have not seen the official documentation from Avid saying that. You can make your own External Drive by buying an External case, and putting a nice WD Caviar Black 32MB cache drive in it. These cases work good for me, it has both E-Sata and USB2.0: http://www.newegg.com/Product/Produc...ill%20RX-358-S and put one of these hard drives in it: http://www.newegg.com/Product/Produc...82E16822136319 http://www.newegg.com/Product/Produc...82E16822136283 http://www.newegg.com/Product/Produc...82E16822136320 I also use external WD Mybook's the Home edition which has E-Sata, USB2.0 and Firewire ports.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks for all the replys and could this be the reason that my mbox 2 clicks on audio when I record it will click on 1 or 2 words in a verse??
It also clicks in adobe audition but my ua25ex doesnt
recording to your OS drive can cause clicks/pops, and other nasty side effects.
Make sure you turn off your wireless adapter. Disable it in Device Manager. That is one of the best known causes of clicks and pops.
Pro Tools LE 8 -- No sound, but strong input signal | carterisgod41 | FireWire & USB Audio Interfaces (Mac) | 15 | 03-18-2014 08:42 PM |
The 10.3 Release is a Strong One. | TOM@METRO | Pro Tools HDX & HD Native Systems (Win) | 1 | 09-13-2012 09:51 PM |
Which universities are strong in computer music | yozloy | General Discussion | 7 | 12-31-2008 03:20 PM |
good strong laptop? | cfinch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-01-2008 10:37 AM |
How Strong is my PC for Digi 001? | ESR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-22-2002 03:35 PM |
