Old 06-30-2010, 02:45 PM
goodfriendelectric goodfriendelectric is offline
Default Sample rate issue, Session was set at 44.1, forgot to change preamp to 44.1,
The session was created for 44.1, however I forgot to change the external clock on my preamp to 44.1 (yes, a very stupid mistake). It was at 48 through out the tracking and mixing. Now when i bounce down the tracks are slowed down about a whole step (by the ratio of 44.1 to 48). What can I do to get the tracks to bounce down at the correct speed.
-as a note through out mixing i had to face the problem of opening the sessions at 44.1 then switching the ext clock to 48 to hear them at the correct speed.
I'm totally lost on how I can get these tracks to bounce down at the correct speed. I found a lot of info for if you have your session at 48 and your preamp/ext clock at 44.1 but not the other way around like my problem.
thanks
tyler
Old 06-30-2010, 03:13 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Sample rate issue, Session was set at 44.1, forgot to change preamp to 44.1,
Use a program like Goldwave to change the playback rate of the audio files to 48K, then hopefully you can relink the files once you go to open the session in LE.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
FocusritePro 40 (2)
TCE Studio Konnekt 48
Rascal Audio Tonebuss 24
Slate Digital VRS8
Gigabyte GA-Z170-HD3P
i7 6700K 4.1 GHz
32GB DDR4
macOS 10.15.7
UAD-2 Octo Core PCIe
Pro Tools Ultimate 2023.3
Old 06-30-2010, 09:33 PM
I ended up doing some trial and error runs but this is how i did it if it helps any one.
-First I bounced the session in 24 bit, 44.1 multi mono.
-created a new 48 session
-switched the external clock to 44.1
-imported the audio to track
-switched the external clock back to 48
-then the audio was fine and just bounced it stereo interleaved (was my first mix to show the band)
Old 06-30-2010, 10:14 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
http://www.railjonrogut.com/HeaderInvestigator.htm
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 06-30-2010, 10:19 PM
Top Jimmy's Avatar
That's an awful lot a something when you can do everything you need to do right in the Pro Tools import audio window.
Files at 48 but headers at 44.1? Import files into 48K session and uncheck the "Apply SRC" option. Files copied with new header and not sample-rate converted.
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
Can I change the sample rate of an existing session? (PT9) bicasaur macOS 2 07-28-2013 01:40 PM
sudden change in session sample rate c-post Pro Tools TDM Systems (Mac) 1 08-23-2006 07:20 PM
Can I change the sample rate of my session? Help! Allbaldo Pro Tools TDM Systems (Mac) 9 05-09-2006 01:05 PM
Sample rate change during session? JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2005 10:47 AM
Can't change Sample Rate in session anymore? Transducr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-21-2004 07:17 AM
