PT7 Dual monitor setup Serious issues.
I'm using 2 23" apple monitors (the new ones) and if I strech the edit or mix windows over 2 pages all the regions dissapear and also whilst "streched out" if you import session data (other tracks) it imports the audio and tracks but doesn't display the regions!!!
.. Also, if you select delete unused regions (even on one monitor) you clear them, do it again and another buch of unused region are selacted. This is very worrying and bythe time you've finished doing all that you're still left with loads of regions in the session which dont belong anywhere. C'mon digidesign this is basic stuff. |
Re: PT7 Dual monitor setup Serious issues.
First question - have you tried trashing preferences yet?
Next - when you say you are stretching the Mix or Edit windows over 2 screens are you talking about each window on it's own screen or do you have one window (Edit, for instance) stretch across both screens? Lastly - what computer model is this? Which video card are you using? What OS version and Pro Tools version (is it just 7.0 or is it 7.1? Have you applied any CS updates)? |
Thanks for your resonse. Its when I strech a edit (or mix window over 2 screens) heres the graphics card and computer info.
What about the delete unused regions issue? that happens even when the mix/edit window is only on one screen. Dual 2.5 Ghz Power G5 Chipset Model: ATY,RV351 Type: Display Bus: AGP Slot: SLOT-1 VRAM (Total): 128 MB Vendor: ATI (0x1002) Device ID: 0x4150 Revision ID: 0x0000 ROM Revision: 113-A58504-113 Displays: Cinema HD Display: Display Type: LCD Resolution: 1920 x 1200 Depth: 32-bit Color Core Image: Supported Main Display: Yes Mirror: Off Online: Yes Quartz Extreme: Supported Rotation: Supported Cinema HD Display: Display Type: LCD Resolution: 1920 x 1200 Depth: 32-bit Color Core Image: Supported Mirror: Off Online: Yes Quartz Extreme: Supported Rotation: Supported |
jimmy 15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5 27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5 Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3 |
thanks, its cs 7.3
what about it digidesign? whadaya say?? does anyone get this delete unused regions problem?
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
Still on Dual monitor setup | gerax | Pro Tools TDM Systems (Win) | 2 | 07-07-2006 12:51 PM |
new to dual monitor setup... | shynomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-09-2005 10:16 PM |
Dual monitor setup question. | odysseys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-05-2002 08:29 AM |
Anyone Using Dual Monitor Setup For Win98? | Chad Bumstead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-14-2000 10:25 AM |
