just recently i noticed on a project i was working on, certain channels were bypassing the master faders' plugins i had in place. this is way weird on a TDM system, when i've never seen this at home on my LE system. example: all channels are set to analog 1-2 out, i have an L1 limiter on the master fader. as i pull down the out ceiling level on the L1, certain channels with transients remained at the same peak level in the master fader meters, yet i could audibly hear the voice over and other effects levels coming down with the L1 adjustment and also see them respond lighter on the master fader meter around the transient hits. if i created a stereo aux track, set all of the track outputs to bus 1-2, feed them the the aux tracks inputs and then out analog 1-2, the L1 limiter placed on the stereo aux track respond as it should - nothing was getting past the limiter including the transient hits. it really is like some tracks are feeding the L1 in the master fader channel, and some are going right past it.
it almost seems to me lime some sort of weird sfotware glitch, unless i am completely missing something or changed some bizzarre preference i didn't know about. any ideas? PT 5.3.3 on a PC, HD system, Pro Control and Edit Pack
Ken P. Pro Tools Ultimate, Mac Mini 3.2 i7, Mtrx Studio & Omni, 4x S1s & Dock w/ iPad Air 2 |
There's an issue with plugins (RTAS?) working only on Aux tracks or something like that. I don't remember how it goes, but here's one answerbase link that might be an answer:
http://answerbase.digidesign.com/detail.cfm?DID=4572
steve Your Heaven |
thanks for the link, steve...unfortunately all of the plugins in use on my system where these problems are occuring are TDM based.
Ken P.
Can you email me a copy of the session file (without any audio) so I can see the session routing? Which version of Waves are you running? Any reason you're not using 6.4 with ADC for mixing (it'll change your life )
Rail
Hi All,
Also, I think it's the same in TDM and LE. the master fader is pre inserts. On all other channels, the fader is post inserts. So, if your hitting the limiter hard and pull the master fader down, what you're actually doing is hitting the limiter less not attenuating the output of the limiter. Hope this helps. Peace, Brandon
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
![]() Quote:
this waves problem just cropped up recently. i never touch the master fader, pretty much it is always at unity. as far as i can tell all of my i/o routings are correct, but maybe you can spot something. here is my PT setup: Sync I/O 192 I/O HD Core Pro Control Edit Pack PT 5.3.3 2.53 GHz Dell, 512 Ram (i should also note that i have 2 PC's with a KVM switch. the Dell above is strictly XP Service Pack 1 and PT only, the other is email, internet, fx library, etc.) i do audio post for video, radio spots and corporate training stuff with this setup, so my sessions are not reall intensive. Ken P.
weird, loud POP and no audio on master fader! | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-13-2008 07:35 AM |
Weird master fader issue | jrmintz | Pro Tools TDM Systems (Mac) | 5 | 05-29-2007 09:20 AM |
major issues with master fader plugins and PT | satchvai | Tips & Tricks | 4 | 04-05-2006 06:57 PM |
Weird master fader problem | Nutsville Noise Lab | Post - Surround - Video | 3 | 11-29-2005 01:19 PM |
Master Fader 6.7 Master Fader issues | Bogner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2005 07:42 AM |
