Has latency of USB interfaced caught up with firewire in the newer devices? There used to be a lot of sub-$500 FW interfaces but now that Thunderbolt has replaced firewire, it seems the TB interfaces are all fairly expensive and the only stuff in the mid and lower ranged are USB.
Is that a step backwards or have newer USB-C devices gotten to be as low latency as the old FW devices? |
RME interfaces using USB deliver the same latency as TB. That’s also USB 2.
Drivers, drivers, drivers. Not all manufacturers are the same. RME aren’t. necessarily the only ones. Sent from my iPhone using Tapatalk |
Well done curated lists of interface latency measurements exist on the web, you can find all that with a Google search.
USB is not being replaced. And Thunderbolt still has limited availability on Windows PCs, even with USB 4's optional inclusion of Thunderbolt 3. |
![]() Quote:
It would seem that USB with the latency of firewire would be ideal now. I just picked up a firewire only MOTU Ultralite. I like it so far for $80 and, again, drivers are important. I have it running on my regular system with Catalina as well as my Pro Tools partition. |
USB 2.0 negotiate at 10 or 20 ms latency depending on features used by the drivers. Good luck going below that. Newer versions obviously faster, but the thing has not been designed for low latency to begin with.
![]() Quote:
https://dawbench.com and a widely used other link to Dawbench is https://gearspace.com/board/music-co...data-base.html Look for the link to the DAWbench PDF doc on that page, that link is kept up to date. I don't see your interface reported in those results. But notice for what is reported that a Motu USB interfaces have lower RTL than the 828 Mk III Firewire interface. The devil us very much in the details with anything involving latency, watch out for ******** like "USB can't do low latency" or "you need thunderbolt" etc. Driver versions matter, OS versions can matter, many driver settings can matter, DAW version and setting matter, etc. And note DAWbench uses (modest) workloads that the system runs while measuring latency, focus has historically been on Reaper. But importantly it's not a no-load latency measurement. Much of the problem with latency masturbation on forums... it's not what somebody else can achieve in a theoretical world but what matters is what IO Buffer setting can you achieve for your DAW and computer and workload, since IO Buffer size will often dominate latencies. You can use the same RTL Tool to measure latency used by DAWBench: https://oblique-audio.com/rtl-utility.php and see how you are doing for your setup vs. others. Dale - since you raised the whole latency concern, please do measure what you have and share here. (want even more detailed breakdown of CoreAudio latency components I have a utility). Last edited by Darryl Ramm; 08-27-2022 at 03:50 PM. |
![]() Quote:
It takes a development team that knows what they are doing. And we've already pointed to RME being a leader there. And since my RME UFX+ does Thunderbolt, USB 3.1, and USB 2 and USB 2 class compliant I can report those RTL measurements. Or at least I would have Thunderbolt measurements if I could find my long Thunderbolt cable. Anyhow these are some no-load measurements (Pro Tools on this system routinely gets used for tracking a few channels in small sessions in Pro Tools at 32 samples with this interface vi USB 3 @ 96 kHz). Code:
Measured RTL @ 96 kHz, samples / ms ---------------------------------------------------- I/O Buffer size: 32 sample 64 sample USB 3 (RME driver) 221 / 2.30 (173 / 1.8)* 285 / 2.97 (237 / 2.47)* USB 2 (RME driver) 221 / 2.30 (173 / 1.8)* 285 / 2.97 (237 / 2.47)* USB 2 Class compliant -- 562 / 5.85 RME Fireface UFX+ Firmware v54 RME USB Driver version v3.27macOS Big Sur 11.6 The UFX+ allows you to switch between USB 3 or USB 2 or USB 2 class compliance modes, the Fireface USB Setting utility is used to check what USB mode the interface is in. And whoa surprise surprise (it was a surprise to me) the USB 2 latencies are exactly equal to the USB 3 latencies. And yes that is real. Under the covers there are differences as well, USB 2 is always running to isochronous mode, USB 3 is defaulting to bulk mode, you can force the driver into isochronous mode (say if the interface is getting errors). Changing that mode made no difference to the latency measured. And while YMMV as to how low an IO buffer size you can run with for your use, here is USB 2 and 3 showing impressive low RTL latency, that is far away from supposed USB 2 10ms or 20ms latency overhead. Last edited by Darryl Ramm; 08-27-2022 at 04:49 PM. |
![]() Quote:
Right, I eat my hat. Nothing beats good testing, well done Darryl
Reaper reports 1.0ms in/1.0ms out with my RME Babyface Pro fs at 96KHz, with a 32 sample buffer. This is using USB2.0.
This is on an M1 Max MBP (in signature) using RME's latest 4.04 beta drivers, but IIRC I got the same figures for the official 3.27 driver. Both drivers are native AS, but the new beta drivers are moved out of the kernel, as per Apple's latest security model. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Monterey 12.6.3, Pro Tools 2022.12, Carbon. |
MIDI recorded latency after playing with no latency | genebackmusic | Pro Tools 12 | 8 | 01-19-2016 02:36 PM |
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
