Old 08-30-2021, 10:43 PM
Rimounette Rimounette is offline
Default Change the simplerate
I would like to change the simple rate 44.1 khz by 48 khz but it is not selectable, sometimes it is but now I can no longer get the drop-down menu, how can I do this?
https://servimg.com/view/12829026/521
* MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
* Processeur 2,3 GHz Intel Core i5 double cœur
* Microphone SE2200
* Pro Tools First
* Memory 8 Go 2133 MHz LPDDR3
* Scarlett Solo Focusrite connected with apple cable
* Graphisme Intel*Iris*Plus Graphics*640 1536 Mo
Many thanks for your precious help
Old 08-31-2021, 06:09 AM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Change the simplerate
Do you have Focusrite Control software installed on your system?
You can go into Focusrite Control, go to device settings and set the sample rate there. Do this before you start Pro Tools.
Will
System Details
Old 01-15-2022, 12:36 PM
tythecelloguy tythecelloguy is offline
Open up Pro tools, but don't open any session or project. Go to the Setup menu, and go to hardware. select "Launch Setup App". Since you have a focusrite, it will open up the focusrite settings window. You can change it to whatever sample rate will be default for future sessions.
Tyler
Old 01-15-2022, 12:56 PM
Ben Jenssen's Avatar
Tyler
Nice try for your first post, but erratic and unprecise. The sample rate is set for each session. To change a session's sample rate, do a "Save session copy…", choose sample rate, save, close current and open the newly created session.
Program Change to change Expand presets amoretam Pro Tools 2018 6 03-13-2019 03:11 PM
Can't change buffer size, It is stuck in 512 and 1024. How can I do to change it? Ariel Chimba Pro Tools 12 9 12-23-2017 11:17 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Eleven Rack doesn't change sound output when I change to a new rig Jlambton Eleven Rack 4 02-28-2011 11:51 PM
