Old 07-09-2012, 07:51 PM
wfenlon wfenlon is offline
Default Digi 002 IO problem
My interface only lists Built in inputs 1 and 2 on the protools 9 software though it has 8 plugins in the back of the 002 or even more using ADAT.
I've reinstalled Pro tools 9 and even tried the default switch but don't see how to record with several instruments.
Mac w/Digi002 Snow Leopard
Old 07-11-2012, 12:33 AM
PD-John PD-John is offline
Default Re: Digi 002 IO problem
Do you mean the Default button on the I/O window? If not, try selecting the 002 as your Playback Engine in Pro Tools first (Setup > Playback Engine), then go to the I/O window (Setup > I/O) and click the "Default" button on the Input and Output tabs. When you do this all the inputs of your 002 should show up.
Old 07-11-2012, 08:02 PM
I thought I had pressed default on the IO but somehow I must have not. That was so simple, and yet I spent hours looking for something more complex. Thank you so much.
Digi oo3 Problem jameelb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-19-2010 07:26 AM
digi 002/7.4 installation problem/not recordable volume problem fifthflaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2008 01:28 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 10:08 AM
Digi 002 sync problem (I need Digi assistance!) sebamars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2005 02:18 PM
Digi 001 Problem! Crooner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-27-2002 11:07 AM
