Old 01-26-2013, 11:25 AM
wfenlon wfenlon is offline
Default OS Held off interrupts for too long?
As I was trying to bounce a recording to disc, it gave me that message. Said to increase buffer size in playback engine but I'm already at maximum 1024. Not sure what to do. Thanks.
Digi 002
Macintosh dual-processor but using an external hard drive for storage
OSX snow leopard
I've read other similar threads but don't see a solution. Posted 2 days ago with a recording problem delay but was able to solve that one.
Old 01-26-2013, 03:11 PM
JazzyJ JazzyJ is offline
Default Re: OS Held off interrupts for too long?
Difficult to diagnose with no specs.
Put your spec in your signature and the job is done.
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 01-26-2013, 10:09 PM
Tried to add specs in an edit of the message.
Macintosh OSX 10.6.8
2.16 Ghz Intel Core 2 Duo
3GB memory plus external HD
I've recorded successfully in the past but was not able to bounce to disk and today the recording process stopped after about 3 minutes of the song, giving that same error message.
Old 01-27-2013, 09:32 PM
Well, it looks like the problem was in the 3 plugins. Just basic EQ and reverb that came with Protools 9. It has recorded with them in the past. I also reduced the DAE playback buffer from level 4 back to level 2 which I had raised due to a different issue. I feel like I've solved the problem without understanding what the issue was. Plus I obviously want to rerecord with the ability to use plug ins, but maybe the problem is clearer to some of you. Thanks for any comments.
Old 01-28-2013, 05:44 AM
Ben Jenssen's Avatar
I would try to trash preferences.
Remember to set PT to use 1 processor less after that.
Old 01-28-2013, 09:23 PM
Sorry for my ignorance, but how do you ''trash preferences"? And You're suggesting using one processor rather than two?
Old 01-29-2013, 04:12 AM
http://duc.avid.com/showthread.php?t=54888
OS Held Off Interrupts for Too Long! Nsufera 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2007 08:35 AM
OS held of interrupts for too long... Norcaldude2003 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2006 02:25 PM
OS held of interrupts for too long... Norcaldude2003 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-16-2006 12:42 PM
..."held off interrupts for too long"... jumpnblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-27-2006 12:16 AM
held off interrupts for too long...!!!...What?!?! groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-13-2003 03:00 AM
