  #51
Old 10-29-2019, 05:58 AM
Stephen Bond's Avatar
Default Re: EQ Curve Supported Plug-Ins
Thanks again Jeff. Good to see things are progressing!
Added them to the list.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #52
Old 11-02-2019, 04:34 AM
Originally Posted by Stephen Bond View Post
Waves V11
Added: EQ Curve support on Pro Tools and Avid S6 for the following plugins: AudioTrack, eMo F2, eMo Q4, F6, GEQ, H-EQ, LinEQ, Q10, RenEQ, RenChannel, RS56
Stephen
As a side note, I wish Apple would get on board with this eq curve thing too. At the moment I turn them off, they're not much use to you if you use third party eqs.
Totally good news about the V11 EQ support for Protools though.
  #53
Old 11-15-2019, 08:29 AM
creativecontrol's Avatar
Greetings,
Here's a few more to add to your list from companies you have already listed.
HARRISON
Harrison AVA Legacy Q
Harrison Mastering EQ
Harrison MPC Channel
McDSP
NF575
Channel G, compact, console, EQ
Filterbank
AE400
AE600
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #54
Old 11-15-2019, 08:41 AM
Cheers Jeff. Duly updated!
Stephen
  #55
Old 12-09-2019, 06:08 AM
Default Re: EQ Curve Supported Plugins
Cheers. Added!
Plugin writers seem pretty slow on the uptake of this new feature. I remember a recent survey from Plugin Alliance one of the questions was did users want this feature implemented? I would have thought they would be doing it as a matter of course.
Could be we end up with a situation like the gain reduction meter where there are numbers of Pro Tools plugins that never use the feature?
Let's hope not.
Stephen
FYI ; and I can't believe it, this is a reply from Plugin Alliance"
Thank you for contacting support and I am happy to help you.
Unfortunately, we no longer support S6. However, if you search online for workarounds with our plugins you might find something useful(;
Best,
Jonathan
Tech Support
Quality Assurance
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
  #56
Old 12-09-2019, 10:14 AM
EddieJones's Avatar
I doubt this is true...the "Search online for a work around" shows they didn't understand the issue. We have reached out to them for clarification and will report back.
  #57
Old 10-25-2020, 09:19 AM
I added a few more to the list. Still needs much better support for this feature!
Stephen
  #58
Old 06-18-2021, 07:56 PM
MixerGuy MixerGuy is offline
Stephen
Agreed.
I sadly don’t see the GML MDW EQ 6 (the newly updated version)
Vsn 5 does NOT support it. :-/
  #59
Old 06-19-2021, 06:04 AM
MDW 6 working fine here with EQ curves.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #60
Old 08-21-2021, 10:01 AM
bobdamit@gmail.com's Avatar
[email protected] bobdamit@gmail.com is offline
Any thoughts or news on when the Waves SSL Channel Strips and Eq plugins will be supported? They're sort of "half supported" in that the eq indicator shows on the channel but the eq graph is still not represented. I'm on waves v12.
HTML code is On
X-curve mr.armadillo Post - Surround - Video 0 04-27-2014 04:32 AM
A little behind the curve but...PT 7.4 OS 10.4.11 ??'s xxicjoy Pro Tools TDM Systems (Mac) 2 06-01-2009 05:26 PM
X-curve plug-in options? Sound Guy Andy Post - Surround - Video 20 08-22-2005 09:44 AM
How can I see my EQ curve? uno1234 Pro Tools TDM Systems (Mac) 3 08-11-2005 02:15 PM
academy curve plug-in setting? anders Tips & Tricks 0 03-15-2001 08:05 PM
