Old 08-26-2003, 05:51 PM
storymaster2k storymaster2k is offline
Default USD Setup
I am having problems with the USD setup utility. It will not acknowledge that the USD is pluged into the Digi Serial Port. It only lets me choose between the modem and Printer port. Thus the USD setup will not recognize the USD. Any thoughts on why this is happening?
Old 08-26-2003, 05:58 PM
kperry kperry is offline
Default Re: USD Setup
USD Setup (and Sync Setup, for that matter) only work when the USD/Sync is plugged into a Mac serial port (not the DigiSerial port). If you need to access the USD parameters through something other than the Session Setup or Peripherals menu, you'll have to plug the USD into a Griffin or Stealth serial port, or a Keyspan USB-serial adapter.... You'll also need to do this to upgrade firmware on the USD.
Kevin Perry
Post-Production Systems Engineer
Dolby Laboratories
San Francisco, CA
Old 08-26-2003, 06:31 PM
Thanks! That's what I thought and I was close to doing but another engineer here swore that this worked before. I know I should always trust my own knowledge!
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
OMS Setup: Interface Req'd? Setup referrences? eltornado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2000 04:17 PM
