Old 11-10-2002, 08:57 PM
storymaster2k storymaster2k is offline
Default Sample Rate Copnversions
I have forgotten how or if you can properly convert a file originally recorded at 48k to a 44.1k file for master to a CD. I just tried it and the end 44.1 result was a bit faster. I remember having this problem before but I can't remember how to work around it.
Old 11-11-2002, 09:56 AM
charles maynes charles maynes is offline
Default Re: Sample Rate Copnversions
I know this is obvious but I will mention it anyway-
Is the system running at 44.1k?
If you have an external clock be sure it is set to the correct SR.
Humbly-
charles maynes
Old 11-11-2002, 05:12 PM
I have checked my session and it is set to 48k. The USD however is set to 44.1. For some reason though, Pro Tools is not seeing the USD, yet when I turn off the USD the speed of the music increases.
What is a solution and how do I get it to 44.1 at the right speed now?
Old 12-03-2002, 04:44 PM
jose oliveira jose oliveira is offline
ok
convert and import audio. [img]images/icons/smile.gif[/img]
porto rox
HTML code is On
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
Bit Rate / Sample rate supersam83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2010 08:55 PM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
Bit rate & Sample Rate WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2002 12:54 AM
