Old 07-04-2003, 08:49 PM
lexluth lexluth is offline
Default PT 5.3.1 will not load drivers - HELP!
My PT 5.3.1 has been running fine up until this evening. When I try to launch Pro Tools, I get an INITIALIZATION ERROR. It says "This software requires installation of certain device drivers and a reboot before using. Please reboot or re-install the software."
I've rebooted several times, ran PT setup and chose "repair" option, and I've even un-installed and re-installed the software, but cannot get past this error message.
Digi Wavedriver is working O.K.
I'm running a P4 2.53 @ 533MHZ FSB, 1.0 GB Corsair 2700 RAM, ASUS P4PE BP Motherboard, Win XP, Antec TruePower 430W power supply, (2) WD 80GB HD's with 8MB cache on a Promise 133 TX2 IDE controller card. I also have an ATI 8500LE video card and the on-board LAN & Sound disabled.
I have not installed any new software that may be conflicting with the Digi001.
Please Help.
Thanks in advance.
Dennis [img]images/icons/confused.gif[/img]
Old 07-04-2003, 09:49 PM
MilesWonderland MilesWonderland is offline
Default Re: PT 5.3.1 will not load drivers - HELP!
Wavedriver SCREWED my system. Try to uninstall the wavedriver and digi001 from the hardware devices then restart and install your software again. Fixed mine!
Good luck
www.DavidKarns.com
002R, AMD2500+
Gear List:
http://www.davidkarns.com/studio.html
Old 07-05-2003, 11:06 AM
rs7k rs7k is offline
I've got the same problem, but with PT 5.3.3 and Mbox.
Still doesen't work yet, if you want let me know how you solved it!
Tried almost everything (re-instelling PT and Windows Xp,updated drivers, prayed,...) nothing worked.
Cheers
Old 07-05-2003, 11:14 AM
I've been unable to resolve the problem. I've un-installed WaveDriver, PT 5.3.1, my USB Keystation drivers, and removed their entries from the registry. Then, I did a fresh install of PT 5.3.1 when Window recognized the Digi001, and this time I did not re-install the WaveDriver. Still, same error. I am unable to lauch Pro Tools at all.
I don't understand, everything was working fine for the last 2 weeks or so.
I'm going to contact DigiDesign on Mon or Tues and see if I can get this resolved. Maybe there's a bug or something that 6.01 might fix. Who knows? I'm keeping my fingers crossed.
If I get a definitive answer, I'll be sure to post it here.
Dennis
Old 07-05-2003, 08:07 PM
Kevin Stone Kevin Stone is offline
I was just having similar problems installing 5.3.1, and also my SBlive wouldn't work. What finally solved it was turning ON USB and Plug And Play in the BIOS setup. Don't ask me why, but it all works great now. I haven't tried Wavedriver since I got PTLE working, I'm afraid of it. I hope this helps.
Old 07-05-2003, 09:28 PM
USB and Plug and Pray are already on in the BIOS, but thanks for the input.
Old 07-06-2003, 06:31 AM
Dang, sorry that didn't help. Are your PACE files intact and in the right place? If they're screwed up you can get that "certain device drivers" error. Good luck.
answerbase link
another one
DUC - Hey, this sounds like your problem
Old 07-06-2003, 09:13 AM
BeefEater BeefEater is offline
I had problems a few months ago with a corrupted PTLE installation. Not the same cause or cnditions but I could not fix or re-install with out doing the following. I do not have the DIGI001 but am retty sure the following applies to you as well.
(be sure to back up your system using ghost, or at least copy the folders before deletion)....
1) Remove PT. Then disconnect the hardware.
2) Open regedit (which you have already done at least once so I won't explain how) and delete the key "HKEY_LOCAL_MACHINE\SOFTWARE\DIGIDESIGN" and all sub folders.
3) If the DIGI001 still remains in the device manager then remove it.
(you can restart but I do not think it is necessary)...
4) Reinstall PTLE/DIGI001 according to the instructions.
I discovered that it was these registry keys that caused all of my problems. I had deleted all kinds of folders on the system and the only one that did anything was hosing Digi's registry settings. But I had to hose all of them to get it to work.
Hope that works for you too....
FYI:
Previous posting
Jason LaMons
CHEAPER
FASTER
BETTER
(pick two)
Old 07-06-2003, 08:47 PM
IT'S FIXED!! The PACE files were missing or corrupted after I de-installed the Bomb-Factory demo plugins. I downloaded the new tpkd file as suggested, installed it, and BANG, everything is now working correctly.
YOU GUYS ARE THE BEST! In fact, one of the main reasons I purchased my Digi001 was because of the DUC. I browsed it for months before I made my purchase. I've never seen such a vast wealth of info and such helpful forum members.
THANK YOU, THANK YOU!
Dennis
Old 07-07-2003, 07:08 PM
Originally posted by lexluth:
IT'S FIXED!! ...
[img]images/icons/grin.gif[/img] Glad to hear it!
...I've never seen such a vast wealth of info and such helpful forum members.
<font size="2" face="Verdana, Arial">It really is a uniquely helpful and friendly place here. I'm happy that I'm finally starting to know enough about this Digi stuff that I can pitch in. Happy recording!
I cant load Mbox 2 mini Drivers on Vista with Protools 8.03 LE HALFTONEtribe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-05-2011 08:29 PM
Pro Tools HD drivers don't load correctly everytime rcd Pro Tools TDM Systems (Win) 0 06-16-2011 11:46 AM
Mbox 2 Pro Drivers dont load at boot up. sheezy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-03-2010 03:15 PM
PT 8 install doesn't load 002 drivers DanDeurloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-11-2009 12:23 PM
How do I make Logic load DAE and native drivers?? Phattlippz Pro Tools TDM Systems (Mac) 1 08-21-2003 11:54 PM
