I have vocalign project 5... its installed.. but does not show up..?
Hal Cragin On the DUC Since The Year 2000 AD Sonoma PT 2024.6 M1, Antelope Orion 32+ Gen3..SSL Sigma summing, Smart Comp C1LA, CharterOak EQP-1, Oceanway Audio HR4S monitors, SSL X-Rack w XR618 compressors, dbx 160x [2] |
You need v.6
Johan Bejerholm World Studios Sweden Phone +46707773443 |
![]() Quote:
Yes iPT-263050 didnt make this release but the fix is coming :) Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
So given nothing is listed in the fixes , can we assume that the issue with Carbon dropping out on Mac Sonoma is not fixed correct ?
System : Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4 Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1 Enjoy the Journey.... Kev... |
tried PT 2024.6 Ultimate. It's not usable for me, because when I start/stop/start playback in a session in a short period of time (about a second), PT doesn't manage to stop and resumes with an error "PT is not able to stop". When this happens, the System Information Window shows an CPU overload. When the session plays normal, the CPU usage is about 20%. Sometimes it doesn't go in to play. Instead the green play button is flashing, but nothing happens. Running picture with VideoSync5 (with Satellite Link). Best Maik EDIT: opened a case: 04822896
PT HDN 2024.10.2, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.6, BM Decklink Extreme 3D ------------ mars13.de Last edited by marsian; 06-21-2024 at 11:05 AM. Reason: Update |
#16
I'm only getting this after closing the prefs window or I/O setup.
After opening/closing I/O setup or prefs I get a -22005 or "PT timed out trying to stop" error after stopping after the first play pass. 100% of the time. Just open prefs or I/O, hit OK. Hit play and stop and the cursor will freeze for a couple of seconds and comes back with the 22005 error or the "timed out" error. When you open system usage you can see that all cores go to 100% and total usage goes to 100% and fully red when this happens. But as said only on the first play/stop after leaving those menus. Happens with prefs, I/O, playback engine and even without changing any setting After that it's fine also on very short/fast play/stop events. F
PTHDnPCIe 2025.6 (OSX15.5), Eucon 25.6, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 06-21-2024 at 07:51 AM. |
#17
![]() Quote:
Yes the Midi latency is still being worked on - reproducing it took a while as cases weren’t being created by users at first. Now that it has been reproduced Engineering is looking into the bigger picture and working on MIDI improvements that hopefully will resolve several issues, including the one strawb and others have mentioned. I will let him know this as well........ Marianna
#18
![]() Quote:
Status: "The Midi latency is still being worked on - reproducing it took a while as cases weren’t being created by users at first. Now that it has been reproduced, Engineering is looking into the bigger picture and working on MIDI improvements that hopefully will resolve several issues, including the one strawb and others have mentioned. " Marianna
#19
Anybody notice that 2024.6 sessions are not nicely backwards compatible?
Opening 2024.6 saved sessions on a 2023.9 system gives a warning message that the Session was created on an incompatible version, and after dismissing that dialog, you are forced to re-save the session. That's gonna be a problem for me.
🖥️ Pro Tools Ultimate 2024.10.1 | Mac Studio M1 Max (64 GB) | Ventura 13.7.1 | Focusrite Red 4Pre 💻 Pro Tools Ultimate 2025.6 | MacBook Pro M3 Pro (18 GB) | Sequoia 15.5 Last edited by moogboy100; 06-21-2024 at 09:00 AM. |
#20
![]() Quote:
I "think" the bug # for the Carbon drop its with Sonoma 14.5 is PT-323033 but if you have a different one, please let me know. This is still listed in the Pro Tools support with macOS Sonoma (Known Issues) Knowledge base article Mark C. the PO is out today so I can follow up Monday if he is in then. Remind me...... Marianna
Izotope RX compatible with PT2024 on windows? | domilik | Pro Tools | 5 | 03-14-2024 05:04 PM |
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
PT 9 troubleshooting and bugs thread | tokolosh | Pro Tools 9 | 13 | 04-26-2011 05:47 AM |
6031 Issues and Observations | Ghengis | Pro Tools TDM Systems (Win) | 58 | 10-20-2009 01:00 AM |
...bugs and other issues... | jrod096 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-25-2005 10:32 AM |
