  #61
Old 06-21-2024, 11:18 AM
climber climber is offline
Default Re: 2024.6
Originally Posted by BCnSTL View Post
Same issue with RePitch Elements - no code anywhere that I can see either in my account online or in Avid Link.
the REDEEM CODE is actually the SERIAL NUMBER!!!
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2024.6, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
  #62
Old 06-21-2024, 11:37 AM
Eric Lambert's Avatar
Default Re: 2024.6
Originally Posted by BScout View Post
The Avid Video Engine is Intel on Apple Silicon. If you open the macOS Activity Monitor, you can see the video engine process as "Intel" (this with Pro Tools being in native mode.)
Same here.
  #63
Old 06-21-2024, 12:03 PM
resonatee resonatee is offline
Default Re: 2024.6
Are there any problems with video engine on Apple Silicon macs? More? Less than on Intel? Is this just an OCD thing? Surely you must realize that re-coding the video engine is no small feat. Let them fix Midi and latency compensation (latency samples limit raised anyone?) issues first.
__________________________________
cMP 2 x 3,46, 128GB Ram
Monterey 12.7.4
Metric Halo 3d 2882 I/O
Lucid 88192 with Blue Sky 5.1 monitoring
10gbE ethernet with True Nas storage
  #64
Old 06-21-2024, 12:09 PM
BScout BScout is offline
Default Re: 2024.6
The video engine comes from Media Composer. So it isn't a Pro Tools vs Avid Video Engine situation. They have to do it for their flagship NLE. (or maybe they have and haven't ported it to Pro Tools)
And, yes, the AVE still isn't great.
Pro Tools Ult 2024.6, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.7RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
  #65
Old 06-21-2024, 04:50 PM
Tweakhead Tweakhead is offline
Default Re: 2024.6
Did anyone else have trouble completing the download of 2024.6 ?
It took me over 30 attempts yesterday, with various browsers, macs, Terminal commands, etc to get it to complete.
Sometimes it would fail after 1GB or so, sometimes every few 100MB, sometimes it could pick up where it left off, then near the end it would completely reset and start again from scratch. I was getting speeds varying from 2MB/sec up to 40MB/sec
Even the Terminal command
HTML Code:
curl -O https://cdn.avid.com/ProTools/2024.6.0/281DIS4T/Pro_Tools_2024.6.0_Mac.dmg
would also stop with multiple errors such as:
curl: (56) Recv failure: Connection reset by peer
or
curl: (55) Send failure: Broken pipe
Finally after hours of frustration I set about 20 different downloads going in parallel with both Safari and Firefox (latest versions), clicking reload each time one failed, and finally got just one to complete.
Is there something substandard going on with Avid's servers ?
I have not had any other large downloads fail consistently like this.
Ethernet/WiFi - same result.
p.s. I just tested again today, and it's doing exactly the same thing. If this is the fault of Avid's server settings, then please fix it for your own sake. It must be at least 10x-ing the load on your servers thru people having to restart again.
A 5GB test file downloaded from https://testfile.org/ got downloaded in 2 mins on the first attempt with zero errors.
  #66
Old 06-21-2024, 05:10 PM
skylar_battles skylar_battles is offline
Default Re: 2024.6
Just downloading everything and checking it out.
Tested, RX, RePitch, and Auto-Align ARA. Everything working so far.
Question, I saw BScout mention that everything is perpetual with a support plan with the exception of Auto-Align 2.
Since I already own a perpetual license to Auto-Align 2, I imagine I'll be safe after the 2 month demo expires since the license is on my physical iLok?
Will test the MIDI stuff in a moment!
Pro Tools Ultimate 2024.6
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.7
  #67
Old 06-21-2024, 06:05 PM
Default Re: 2024.6
Yes, it's an issue, and in my experience it's one more troublesome than MIDI or latency, which I'm not seeing. I don't know how Intels respond -- all my production machines are Silicon.
They've had a very long time to work on this, and it's not the ProTools crew doing the work, it's the video team.
No, it's not OCD. When the video engine crashes it's not possible to work. That's a bit outside the nitpicks of OCD.
  #68
Old 06-21-2024, 08:18 PM
smurfyou smurfyou is offline
Default Re: 2024.6
It's been 4 years now. Since the M1 dev kit was released.
There have been issues ever since the AVE was implemented in PT. Biggest one for me is the fact that it's an external process and has some inherent latency. I'm not sure if they'll ever solve that but at least they can keep the architecture current. And maybe have it use less than 6GB RAM at idle
~Will
  #69
Old 06-22-2024, 10:52 AM
Default Re: 2024.6
Interesting. I've never noticed latency other than what is introduced by the HDMI connection (which is only 1 frame). The large RAM grab is also strange. It seems to reserve that amount regardless of what it actually needs.
What is still occurring is the forgetting of the window size on external monitors. With 2024.6 I'm still opening up sessions only to find that the "Full Screen" setting is displaying a much smaller window. The menu says that it's full screen -- it is not.
  #70
Old 06-22-2024, 01:14 PM
koka koka is offline
Default Re: 2024.6
Originally Posted by marianna View Post
The Video Engine should be both Apple silicon and Intel already....
Marianna
Thanks for response
Im on Mac pro 6.1 and Monterey 12.7.5
Can I go to 2024.6 HD driver ?
PT 2024.3 | Released TrentWilliams Pro Tools 222 06-16-2024 07:03 AM
PT Ultimate 2024.3.1 mhender Pro Tools 7 04-24-2024 07:38 AM
PT 2024.3 with D-command Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 3 03-25-2024 03:52 AM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
